Michaelv
  1. I did the factory reset, added it back and it is now communicating. Thanks!
  2. It does not detect a single tap. Increment a variable did not work. I can control the switch from thew admin console.
  3. Recently, a trigger is not working in my Eisy universe. I would double tap an Insteon Dimmer ( 2477D - Dual Band Switchlinc Dimmer v.45) to trigger an event in Homeseer and now it does not work. So, I opened up event viewer, selected level 3. Device communications, did a double tap. and there was no response. But, when I click fast on or fast off on the device page in the MAIN tab, I get the communication event information. How can restore the communication when I physically double tap it? I have tried restoring the device, but that did not work.
  4. Ok, Tried the reset / Restore and no luck. Yes, I do have other routines that are working using fast on / Fast off as a trigger but those programs / scenes are in the EISY universe, not homeseer. so, I guess that would be a no.
  5. Along with my EISY, I use Homeseer to integrate my security system, HVAC, among other systems in my home. I wrote an event to adjust the temp of a Honeywell Thermostat when I would double tape ( fast on) an Insteon 2477D Dimmer switch. It worked for years and now all of a sudden it does not work. I started with the Homeseer Help Desk and they directed me to the author of the Insteon Plug In. He said his latest plug in does not support the EISY and that I would have to report the issue with the ISY forum. The thermostats are controlled by Homeseer through the Honeywell Total Connect comfort with a Homeseer Plug in.
  6. That worked! I am connected. I replace the USB cable just to be on the safe side! Thanks!!
  7. this? I have restarted 3 times and still get the not connected status? What about a PLM restore?
  8. Here is a picture and the LED is lit. do I just keep restarting the EISY?
  9. I replaced a few Insteon switches that had burned out but when I went to start linking them, the EISY wont run the link management tool. I then tried controlling some switches from the administrative console and I get "Request Failed" Then I got this: Never seen this before. What is going on?!? here is what i'm running:
  10. I have an all Off scene with Insteon dimmers that does not work reliably. I tried looking at scene test and this was the result. Sun 11/24/2024 11:57:44 AM : Create REST U7 [/rest/nodes/28450/cmd/DOF] Sun 11/24/2024 11:57:44 AM : U7 Rest: submitCmd([28450],[DOF],[<NULL>]) Sun 11/24/2024 11:57:44 AM : [INST-TX-I1 ] 02 62 00 00 2C CF 13 00 Sun 11/24/2024 11:57:44 AM : [LINK-INFO ] Link for responder 52 AA 15 1 not found Sun 11/24/2024 11:57:44 AM : [LINK-INFO ] Link for responder 44 C8 17 6 not found Sun 11/24/2024 11:57:44 AM : [LINK-INFO ] Link for responder 39 85 F1 1 not found Sun 11/24/2024 11:57:44 AM : [LINK-INFO ] Link for responder 70 C3 23 1 not found Sun 11/24/2024 11:57:44 AM : [LINK-INFO ] Link for responder 33 48 89 1 not found Sun 11/24/2024 11:57:44 AM : [LINK-INFO ] Link for responder 41 99 B5 1 not found Sun 11/24/2024 11:57:44 AM : [LINK-INFO ] Link for responder 38 EA 62 1 not found Sun 11/24/2024 11:57:44 AM : [LINK-INFO ] Link for responder 70 F0 25 1 not found Sun 11/24/2024 11:57:44 AM : [INST-ACK ] 02 62 00.00.2C CF 13 00 06 LTOFFRR(00) Sun 11/24/2024 11:57:44 AM : [D2D EVENT ] Event [52 AA 15 1] [ST] [0] uom=100 prec=0 Sun 11/24/2024 11:57:44 AM : [52 AA 15 1 ] ST 0 (uom=100 prec=0) Sun 11/24/2024 11:57:44 AM : [D2D EVENT ] Event [70 BC A 1] [ST] [0] uom=100 prec=0 Sun 11/24/2024 11:57:44 AM : [70 BC A 1 ] ST 0 (uom=100 prec=0) Sun 11/24/2024 11:57:44 AM : [D2D EVENT ] Event [44 C8 17 6] [ST] [0] uom=100 prec=0 Sun 11/24/2024 11:57:44 AM : [44 C8 17 6 ] ST 0 (uom=100 prec=0) Sun 11/24/2024 11:57:44 AM : [D2D EVENT ] Event [39 85 F1 1] [ST] [0] uom=100 prec=0 Sun 11/24/2024 11:57:44 AM : [39 85 F1 1 ] ST 0 (uom=100 prec=0) Sun 11/24/2024 11:57:44 AM : [D2D EVENT ] Event [70 C3 23 1] [ST] [0] uom=100 prec=0 Sun 11/24/2024 11:57:44 AM : [70 C3 23 1 ] ST 0 (uom=100 prec=0) Sun 11/24/2024 11:57:44 AM : [D2D EVENT ] Event [33 48 89 1] [ST] [0] uom=100 prec=0 Sun 11/24/2024 11:57:44 AM : [33 48 89 1 ] ST 0 (uom=100 prec=0) Sun 11/24/2024 11:57:44 AM : [D2D EVENT ] Event [41 99 B5 1] [ST] [0] uom=100 prec=0 Sun 11/24/2024 11:57:44 AM : [41 99 B5 1 ] ST 0 (uom=100 prec=0) Sun 11/24/2024 11:57:44 AM : [D2D EVENT ] Event [38 EA 62 1] [ST] [0] uom=100 prec=0 Sun 11/24/2024 11:57:44 AM : [38 EA 62 1 ] ST 0 (uom=100 prec=0) Sun 11/24/2024 11:57:44 AM : [D2D EVENT ] Event [70 F0 25 1] [ST] [0] uom=100 prec=0 Sun 11/24/2024 11:57:44 AM : [70 F0 25 1 ] ST 0 (uom=100 prec=0) Sun 11/24/2024 11:57:45 AM : Create REST U7 [/rest/nodes/D%20A1%2093%201] Sun 11/24/2024 11:57:45 AM : Create REST U7 [/rest/nodes/58%2097%201%201] Sun 11/24/2024 11:57:45 AM : Create REST U7 [/rest/nodes/D%20B0%209B%201] Sun 11/24/2024 11:57:45 AM : Create REST U7 [/rest/nodes/4B%20CD%2023%201] Out of these 8 nodes, only 4 or 5 actually shut off. What needs to be done?
  11. One Last observation, So, I made that scene with a total of 88 devices and 1 controller, which is button C on a Insteon 2334-2 Keypadlinc Dimmer. While the scene works, if I press the controller button again, all the lights that are supposed to shut off, come back on. If I press it again, they go off again. Is there a way to configure the controller so it on turns this scene off? What should the status button light do? I guess I would want the status light off all the time and maybe only illuminate while being pressed. What do you think makes the most sense?
  12. I was always concerned that having so many devices in a scene would be problematic. I would have to put 75 devices in one scene to achieve what I was trying to do here. Is there a limit on how many devices can be in a scene? Can a controller of a scene be used in multiple scenes?
  13. Yes, I wrote the trigger as fast on but when I tried to check the communication with event viewer, I only tapped the button once to see if there was communication. I tried the fast on command several times before I posted this topic and it did not work.
  14. Your program is written to trigger on "FAST ON". You are executing a standard "ON" at the switch.
