sreev
  1. Good workaround suggestion brad77! Thanks for your insight. There is really no reason to use the default group - it was just convenient that all lights were already in the group and I am not controlling appliances or garage doors. It was not a typo. Before going to sleep, I first turned My Lighting ON to go into the kitchen. Then after returning to the bedroom, I clicked All Off. When I woke up to cold 54 F, I first suspected that All OFF set thermostats mode to off. Upon testing I found that ON was actually setting thermostats to off. All OFF does not change anything on the thermostats.
  2. I just upgraded two Venstar thermostat adapters to V2.0. When I turn ON the scene "My Lighting" (it is the default group with all devices listed including thermostats), Mode on both thermostats switches to OFF. I found this the hard way when temperature in the bedroom dropped to 52 degrees while we were asleep. Unlike in scenes, I cannot set thermostat settings in "My Lighting" group. Could someone please explain what I may be doing wrong?
