chachdog
  1. Thanks for your reply. I opened a case. udx 3.5.5 freebsd 13.
  2. My networking broke also but I did not upgrade anything. I am on 5.8. I was in the gui and had plugged in some usb stick\hard drives when this all stopped working. I ran the dhcp command and it gave me an ip but it did not work upon a reboot. When running the dhcp command it does say unknown dhcp option value 0x7d but gets an ip. Should I run that script also even though I didn't upgrade to 5.9? I also did not see my plm in the diagnostics menu. Thanks
  3. i just found this.. https://irdb.globalcache.com/Home/Database
  4. format looks different. how do you convert it? Device Code: 7.7 Function: 67DTV 0000 006D 0000 0022 00AC 00AC 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0689
  5. Is it possible to build the sendir commands manually without the ilearn app? can i look on the internet for discreet codes and modify them or is it different format?
  6. I hadn't' hit save i guess outside the resource editor. It works!
  7. test is grayed out
  8. Trying to follow the steps to setup a resource to turn the tv ON. i have ilearned it, and send IR in the tool turns on the tv. I copied it to the body, added /r/n to the end hit update and save. sendir,1:1,2,37993,1,1,171,170,21,64,21,64,21,64,21,22,21,22,21,22,21,22,21,22,21,64,21,64,21,64,21,22,21,22,21,22,21,22,21,22,21,22,21,64,21,22,21,22,21,22,21,22,21,22,21,22,21,64,21,22,21,64,21,64,21,64,21,64,21,64,21,64,21,1782,171,170,21,64,21,64,21,64,21,22,21,22,21,22,21,22,21,22,21,64,21,64,21,64,21,22,21,22,21,22,21,22,21,22,21,22,21,64,21,22,21,22,21,22,21,22,21,22,21,22,21,64,21,22,21,64,21,64,21,64,21,64,21,64,21,64,21,1781/r/n Changed to tcp,ip port 4998 timeout 500ms mode C Escaped set up new program , assigned resource to then (The drop down arrow next to resource it is blank.) tried to run then but no activity on the IR lights on the tv. Am I missing something. Is it a ilearn repeat or connector or module setting? and my test button is grayed out.
  9. so if the battery is low you have to put it in linking mode to see that? I see a motion sensor batt low in the isy but not sure when or if it does anything.
  10. I have 8 insteon switches within 10 of each other and the plm is right there too. They are all new and dual band. The lights are low voltage and LED, not sure if that matters.
  11. I thought I had this motion sensor set to only trigger ON. IE not turn anything off. The off is handled with a 10 min wait > turn scene off Guest Bath Motion 1 - [iD 0021][Parent 0020] If Control 'Guest Bath / Guest Bath-Sensor' is switched On Then Set Scene 'Guest Bath / Guest Bath Lights All' On Wait 10 minutes Set Scene 'Guest Bath / Guest Bath Lights All' Fade Down Else - No Actions - (To add one, press 'Action')
  12. this time nothing came on Fri 12/25/2015 11:30:00 AM : [iNST-SRX ] 02 50 36.93.D7 00.00.01 CB 13 01 LTOFFRR(01) Fri 12/25/2015 11:30:00 AM : [std-Group ] 36.93.D7-->Group=1, Max Hops=3, Hops Left=2 Fri 12/25/2015 11:30:00 AM : [D2D EVENT ] Event [36 93 D7 1] [DOF] [1] uom=0 prec=-1 Fri 12/25/2015 11:30:00 AM : [ 36 93 D7 1] DOF 1 Fri 12/25/2015 11:30:00 AM : [D2D EVENT ] Event [36 93 D7 1] [sT] [0] uom=0 prec=-1 Fri 12/25/2015 11:30:00 AM : [ 36 93 D7 1] ST 0 Fri 12/25/2015 11:30:00 AM : [iNST-SRX ] 02 50 2D.47.F5 38.FF.95 41 11 01 LTONRR (01) Fri 12/25/2015 11:30:00 AM : [std-Cleanup ] 2D.47.F5-->ISY/PLM Group=1, Max Hops=1, Hops Left=0 Fri 12/25/2015 11:30:00 AM : [D2D EVENT ] Event [2D 47 F5 1] [DON] [0] uom=0 prec=-1 Fri 12/25/2015 11:30:00 AM : [ 2D 47 F5 1] DON 0 Fri 12/25/2015 11:30:00 AM : [D2D-CMP 0015] CTL [2D 47 F5 1] DON op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Fri 12/25/2015 11:30:00 AM : [iNST-SRX ] 02 50 36.93.D7 00.00.01 CB 13 01 LTOFFRR(01) Fri 12/25/2015 11:30:00 AM : [std-Group ] 36.93.D7-->Group=1, Max Hops=3, Hops Left=2 Fri 12/25/2015 11:30:00 AM : [D2D EVENT ] Event [36 93 D7 1] [DOF] [1] uom=0 prec=-1 Fri 12/25/2015 11:30:00 AM : [ 36 93 D7 1] DOF 1 Fri 12/25/2015 11:30:00 AM : [iNST-SRX ] 02 50 36.93.D7 38.FF.95 41 13 01 LTOFFRR(01) Fri 12/25/2015 11:30:00 AM : [std-Cleanup ] 36.93.D7-->ISY/PLM Group=1, Max Hops=1, Hops Left=0 Fri 12/25/2015 11:30:00 AM : [iNST-DUP ] Previous message ignored. Fri 12/25/2015 11:30:00 AM : [iNST-SRX ] 02 50 36.93.D7 13.01.01 CB 06 00 (00) Fri 12/25/2015 11:30:00 AM : [std-Group ] 36.93.D7-->13.01.01, Max Hops=3, Hops Left=2 Fri 12/25/2015 11:30:00 AM : [iNST-INFO ] Previous message ignored. Fri 12/25/2015 11:30:01 AM : [iNST-SRX ] 02 50 36.93.D7 13.01.01 C3 06 00 (00) Fri 12/25/2015 11:30:01 AM : [std-Group ] 36.93.D7-->13.01.01, Max Hops=3, Hops Left=0 Fri 12/25/2015 11:30:01 AM : [iNST-INFO ] Previous message ignored. Fri 12/25/2015 11:30:01 AM : [iNST-SRX ] 02 50 2D.47.F5 38.FF.95 47 11 01 LTONRR (01)
  13. I wired a new bathroom fixture in, I stole power from a near by junction box. All the devices in question (kitchen and bathroom) are within 10 feet of each other. The isy shows the light is on but is not. I captured the log when it happened. When the motion kicked sensor fired, the shower LED is the only one that came on even though they are in a scene together. Motion Sensor 36.93.D7 bath light 32.92.B6 shower LED 32.97.60 Wall LED 3B.A5.38 Fri 12/25/2015 10:23:40 AM : [iNST-SRX ] 02 50 36.93.D7 00.00.01 CB 11 01 LTONRR (01) Fri 12/25/2015 10:23:40 AM : [std-Group ] 36.93.D7-->Group=1, Max Hops=3, Hops Left=2 Fri 12/25/2015 10:23:40 AM : [D2D EVENT ] Event [36 93 D7 1] [DON] [1] uom=0 prec=-1 Fri 12/25/2015 10:23:40 AM : [ 36 93 D7 1] DON 1 Fri 12/25/2015 10:23:40 AM : [D2D-CMP 0021] CTL [36 93 D7 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Fri 12/25/2015 10:23:41 AM : [iNST-TX-I1 ] 02 62 00 00 11 CF 11 00 Fri 12/25/2015 10:23:41 AM : [D2D EVENT ] Event [36 93 D7 1] [sT] [255] uom=0 prec=-1 Fri 12/25/2015 10:23:41 AM : [ 36 93 D7 1] ST 255 Fri 12/25/2015 10:23:41 AM : [iNST-SRX ] 02 50 36.93.D7 00.00.01 C7 11 01 LTONRR (01) Fri 12/25/2015 10:23:41 AM : [std-Group ] 36.93.D7-->Group=1, Max Hops=3, Hops Left=1 Fri 12/25/2015 10:23:41 AM : [iNST-DUP ] Previous message ignored. Fri 12/25/2015 10:23:41 AM : [iNST-ACK ] 02 62 00.00.11 CF 11 00 06 LTONRR (00) Fri 12/25/2015 10:23:41 AM : [D2D EVENT ] Event [3B A5 38 1] [sT] [109] uom=0 prec=-1 Fri 12/25/2015 10:23:41 AM : [ 3B A5 38 1] ST 109 Fri 12/25/2015 10:23:41 AM : [D2D EVENT ] Event [38 92 B6 1] [sT] [153] uom=0 prec=-1 Fri 12/25/2015 10:23:41 AM : [ 38 92 B6 1] ST 153 Fri 12/25/2015 10:23:41 AM : [D2D EVENT ] Event [32 97 60 1] [sT] [102] uom=0 prec=-1 Fri 12/25/2015 10:23:41 AM : [ 32 97 60 1] ST 102 Fri 12/25/2015 10:23:42 AM : [iNST-SRX ] 02 50 36.93.D7 38.FF.95 4A 11 01 LTONRR (01) Fri 12/25/2015 10:23:42 AM : [std-Cleanup ] 36.93.D7-->ISY/PLM Group=1, Max Hops=2, Hops Left=2 Fri 12/25/2015 10:23:42 AM : [iNST-DUP ] Previous message ignored. Fri 12/25/2015 10:23:42 AM : [iNST-SRX ] 02 50 36.93.D7 11.01.01 CB 06 00 (00) Fri 12/25/2015 10:23:42 AM : [std-Group ] 36.93.D7-->11.01.01, Max Hops=3, Hops Left=2 Fri 12/25/2015 10:23:42 AM : [iNST-INFO ] Previous message ignored. Fri 12/25/2015 10:23:42 AM : [iNST-SRX ] 02 50 36.93.D7 11.01.01 CB 06 00 (00) Fri 12/25/2015 10:23:42 AM : [std-Group ] 36.93.D7-->11.01.01, Max Hops=3, Hops Left=2 Fri 12/25/2015 10:23:42 AM : [iNST-INFO ] Previous message ignored. Fri 12/25/2015 10:23:45 AM : [iNST-SRX ] 02 50 36.A6.77 00.00.01 CF 11 01 LTONRR (01) Fri 12/25/2015 10:23:45 AM : [std-Group ] 36.A6.77-->Group=1, Max Hops=3, Hops Left=3 Fri 12/25/2015 10:23:45 AM : [D2D EVENT ] Event [36 A6 77 1] [DON] [1] uom=0 prec=-1 Fri 12/25/2015 10:23:45 AM : [ 36 A6 77 1] DON 1 Fri 12/25/2015 10:23:45 AM : [D2D-CMP 001A] CTL [36 A6 77 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Fri 12/25/2015 10:23:45 AM : [ Time] 10:23:47 0(0) Fri 12/25/2015 10:23:46 AM : [iNST-SRX ] 02 50 36.A6.77 00.00.01 CF 11 01 LTONRR (01) Fri 12/25/2015 10:23:46 AM : [std-Group ] 36.A6.77-->Group=1, Max Hops=3, Hops Left=3 Fri 12/25/2015 10:23:46 AM : [iNST-DUP ] Previous message ignored. Fri 12/25/2015 10:23:46 AM : [iNST-SRX ] 02 50 36.A6.77 38.FF.95 45 11 01 LTONRR (01) Fri 12/25/2015 10:23:46 AM : [std-Cleanup ] 36.A6.77-->ISY/PLM Group=1, Max Hops=1, Hops Left=1 Fri 12/25/2015 10:23:46 AM : [iNST-DUP ] Previous message ignored. Fri 12/25/2015 10:23:46 AM : [iNST-SRX ] 02 50 36.A6.77 11.01.01 CF 06 00 (00) Fri 12/25/2015 10:23:46 AM : [std-Group ] 36.A6.77-->11.01.01, Max Hops=3, Hops Left=3 Fri 12/25/2015 10:23:46 AM : [iNST-INFO ] Previous message ignored. Fri 12/25/2015 10:23:47 AM : [iNST-SRX ] 02 50 36.A6.77 11.01.01 CF 06 00 (00) Fri 12/25/2015 10:23:47 AM : [std-Group ] 36.A6.77-->11.01.01, Max Hops=3, Hops Left=3 Fri 12/25/2015 10:23:47 AM : [iNST-INFO ] Previous message ignored. Fri 12/25/2015 10:23:47 AM : [iNST-TX-I1 ] 02 62 38 A6 13 0F 11 77 Fri 12/25/2015 10:23:47 AM : [iNST-ACK ] 02 62 38.A6.13 0F 11 77 06 LTONRR (77) Fri 12/25/2015 10:23:48 AM : [iNST-SRX ] 02 50 38.A6.13 38.FF.95 2F 11 77 LTONRR (77) Fri 12/25/2015 10:23:48 AM : [std-Direct Ack] 38.A6.13-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Fri 12/25/2015 10:23:57 AM : [iNST-SRX ] 02 50 36.A6.77 00.00.01 CF 11 01 LTONRR (01) Fri 12/25/2015 10:23:57 AM : [std-Group ] 36.A6.77-->Group=1, Max Hops=3, Hops Left=3 Fri 12/25/2015 10:23:57 AM : [D2D EVENT ] Event [36 A6 77 1] [DON] [1] uom=0 prec=-1 Fri 12/25/2015 10:23:57 AM : [ 36 A6 77 1] DON 1 Fri 12/25/2015 10:23:57 AM : [D2D-CMP 001A] CTL [36 A6 77 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Fri 12/25/2015 10:23:57 AM : [ Time] 10:23:58 0(0) Fri 12/25/2015 10:23:58 AM : [iNST-TX-I1 ] 02 62 38 A6 13 0F 11 77 Fri 12/25/2015 10:23:58 AM : [iNST-SRX ] 02 50 36.A6.77 00.00.01 CF 11 01 LTONRR (01) Fri 12/25/2015 10:23:58 AM : [std-Group ] 36.A6.77-->Group=1, Max Hops=3, Hops Left=3 Fri 12/25/2015 10:23:58 AM : [iNST-DUP ] Previous message ignored. Fri 12/25/2015 10:23:58 AM : [iNST-ACK ] 02 62 38.A6.13 0F 11 77 06 LTONRR (77) Fri 12/25/2015 10:23:59 AM : [iNST-SRX ] 02 50 38.A6.13 38.FF.95 23 11 77 LTONRR (77) Fri 12/25/2015 10:23:59 AM : [std-Direct Ack] 38.A6.13-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Fri 12/25/2015 10:23:59 AM : [iNST-SRX ] 02 50 36.A6.77 38.FF.95 4B 11 01 LTONRR (01) Fri 12/25/2015 10:23:59 AM : [std-Cleanup ] 36.A6.77-->ISY/PLM Group=1, Max Hops=3, Hops Left=2 Fri 12/25/2015 10:23:59 AM : [D2D EVENT ] Event [36 A6 77 1] [DON] [0] uom=0 prec=-1 Fri 12/25/2015 10:23:59 AM : [ 36 A6 77 1] DON 0 Fri 12/25/2015 10:23:59 AM : [D2D-CMP 001A] CTL [36 A6 77 1] DON op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Fri 12/25/2015 10:23:59 AM : [ Time] 10:24:00 0(0) Fri 12/25/2015 10:24:00 AM : [iNST-SRX ] 02 50 36.A6.77 11.01.01 CF 06 00 (00) Fri 12/25/2015 10:24:00 AM : [std-Group ] 36.A6.77-->11.01.01, Max Hops=3, Hops Left=3 Fri 12/25/2015 10:24:00 AM : [iNST-INFO ] Previous message ignored. Fri 12/25/2015 10:24:00 AM : [iNST-TX-I1 ] 02 62 38 A6 13 0F 11 77 Fri 12/25/2015 10:24:00 AM : [iNST-SRX ] 02 50 36.A6.77 11.01.01 CF 06 00 (00) Fri 12/25/2015 10:24:00 AM : [std-Group ] 36.A6.77-->11.01.01, Max Hops=3, Hops Left=3 Fri 12/25/2015 10:24:00 AM : [iNST-INFO ] Previous message ignored. Fri 12/25/2015 10:24:00 AM : [iNST-ACK ] 02 62 38.A6.13 0F 11 77 06 LTONRR (77) Fri 12/25/2015 10:24:00 AM : [iNST-SRX ] 02 50 38.A6.13 38.FF.95 2F 11 77 LTONRR (77) Fri 12/25/2015 10:24:00 AM : [std-Direct Ack] 38.A6.13-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
  14. I have 2 scenes that have this issue that I know of. Lately they have both been missing a device or 2 when the scenes are called by motion but if you hang out long enough to trigger another motion, it eventually comes on and some times it works as it should. I have rebooted the isy and it didn't help. Is there any way I can see why this maybe happening? thanks
  15. I factory reset it, removed it and readded it. seems to be turning off now. weird
