jbonvallet
Everything posted by jbonvallet
  1. Credit goes to lgilsenberg. I just added to it.
  2. Worked for me, However in step 4 after selecting device, i have to hit the gear symbol (upper right) then the trash icon (upper right). Thanks
  3. Same Problem. We have become very reliant on this singularity (Dangerous). All of my devices do not show up in the device list (Only 8 of them). However, when I go to Groups and add devices to a group all 85 of them show up including the duplicates and some triplicates. Just can’t delete them. The stupidity of allowing a duplicates and then later telling me “I found more than one device with the name xxxxx give them unique name…” How about not allowing duplicates in the first place. And now they have removed the ability to delete them. First they screw up (allowing duplicates) then they screw up a second time by remove the feature to fix the first screw up (Deleting Devices). My reliance on this is unfortunately large and Amazon may not actively support the fringe tech guys, however this is my main reason for paying for Prime each year.
  4. Thanks LeeG. I forgot about the Fade Up Fade Down and Ramp rate. The wording within the Universal Devices is confusing and should be changed. I will re-cap for others having this issue. Fade Up/Down is a fixed rate that you cant control and is around 2 seconds. Ramp rate controls how fast a light comes on and off within a scene. When you set a scene use the on or off to utilize the ramp rate that is set in the scene. Using the fade up or down, will cause it to use a 2 second ramp rate. Ramp rates set to 9 min will cause newer equipment to come on in .2 seconds. If your scene lighting ramp rate is not working check the following: 1. Ramp rate not set to 9 min (use 8 min or less) 2. Do not use fade up or fade down to set the scene 3. Use the On or Off when Setting the scene.
