ddsaitta
  1. Hi Michel, This happened when I unplugged a device (I was working outside and needed the outlet) and forgot to plug it back in before sunset. Once I plugged the device back in, I manually ran (via Admin console) the program's 'then' clause and it worked fine. If you're sure this works in version 2.7.12, I'll try to recreate the condition. Thanks, Dave
  2. I've noticed that during the execution of a program, if the ISY cannot communicate to a device it will not execute the remainder of the program. I'm not sure if this behavior is new with version 2.7.12. Is this by design? Should the ISY continue execution of the program? For example, a program sets five devices at sunset everyday. If the ISY cannot communicate to the first device (broken, unplugged, whatever), none of the devices get set. Thanks, Dave
  3. Hi, I successfully upgrade from 2.7.7 to 2.7.9 and was happy to be able to add an EzSnsRF (with two sensors) without issue. Thank you. I have two Icon Switch Dimmers (2876DB) and previously had to add them to the ISY as another type of Icon Dimmer, since the 2876DB was not supported yet. With 2.7.9 I was able to add them as the correct type (2876DB) but noticed in a program there’s no longer the option to set the on level (only on or off). Is this a known issue? Should I be able to set the on level as a percentage? Thanks.
