born2dive
  1. I have created a few log files on the ISY that are populated when certain events happen. All files are formatted as CSV and are accessible using a browser from the ISY web server. I can manually copy the files to my local machine from the ISY. I am trying to find out if there is a way to automate that copy so it happens on it's own at the set interval, say daily or hourly. Is that possible? Any help would be appreciated. Thanks.
  2. Is there a way to enable and disable ISY devices, remotely while I am away, using a program? Reading through the forum, I guess one way is to use variable and use it as a proxy for the device but that does not really disable the device. Any thoughts or examples would be appreciated. Thanks.
  3. That did it! Thank You!
  4. Hi, I am a Mac user and have been for a very long time. I don't own any Windows machines. So I am not a Windows expert. I recently installed Windows 10 (using BootCamp) on my Mac so I can run 1 programs that is only available for Windows and I need it for work. I installed the ISY Admin Console and it placed an icon on my desktop. The problem is that when I launch the console, the text is tiny and basically unusable. I have a high DPI Apple display. Everything else e.g. the program I needed, firefox, etc, looks fine. It's just the admin console that seems to have the problem. Any ideas how to fix? I can always continue to just use the console on the Mac side so this is not a huge deal but would be nice to get sorted out. Thanks.
  5. I have an August lock that is connected to my ISY on a Z Wave network. If I right-click on the lock on the admin console, choose Z-Wave, then Set Configuration Parameters, I get the attached pop-up. Anyone knows what those mean? Thanks.
  6. Thank you both for your ideas. Will try both options.
  7. Is there a way to generate a report that shows a list of programs that use a specific scene or device on the ISY? Thanks.
  8. I have read quite a few posts related to this topic but nothing that really answered my question. So I am hoping someone may have the answer. My pool is controlled by a Pentair EasyTouch. Based on what I read, it seems that the best way to integrate my pool control into my ISY is using the Autelis controller (I just ordered one). How do I actually add the Autelis to the ISY? Is it discovered like a device? Is there a step-by-step somewhere? Thanks.
  9. Thanks. This was helpful. I finally figured it out. I was setting my folder condition based on an integer variable which was not triggering the status change properly. I changed it to a state variable and now it's working as expected. Thanks again.
  10. Where can I find a listing of all the admin console icons and there meaning? Specifically, if I have a folder with a folder condition set, I see a red bar on the folder icon. Is it always supposed to be red or will it turn green or some other color when the condition is met? Mine is always red even when the condition is met. Thanks.
  11. Here is my use case: Liquor cabinet that is equipped with a open/close sensor Cam plugged and pointed toward that cabinet When the cabinet is opened, I'd like the cam to take a picture and email it to me I use the ISY portal and network module I have a Nest Cam if that works, otherwise I can buy another cam that can do the trick. I know the Nest Cam has a motion sensor and can detect events. I want it to only trigger and email when the cabinet door is open. I tried playing with IFTTT with the ISY and was not able to get it to do what I want. Thoughts/Ideas? Thanks.
  12. It's working now...HTTPS vs HTTP! Thanks.
  13. I would like some help as I still cannot get it to work. So I signed up for pushover. paid for the full license. I registered and linked my iPhone and I can see it in my devices on pushover.net. I can push a test message from my account in pushover.net and I get the message on the iPhone. I have a user key. I created an application in Pushover and have its key as well. I setup the network resource in ISY, screenshot attached. I wrote a small program to test that it works. It doesn't! What am I missing? Thanks.
  14. thank you both...down to 2! will take a look at both and pick one. Will be nice to lose the SMS notifications either way.
  15. I am trying to decide which platform to use. I am using iOS so I am down to 3 choices: Prowl Pushover Pushsafer Any advice on which to use or best practice to setup push notifications? Thanks.
