wacvmd
  1. When upgrading to 5.9.1 on eisy using UD Mobile it asks 'Force Upgrade'. Should I do it not?
  2. Install Dev. Packages is right next to Upgrade Packages in configuration setting
  3. What is the difference between upgrade packages and install Dev. Packages? When should each be used? Thanks in advance for any answers. Thanks, wac
  4. no, i added it to a scene.
  5. I have a question about Yolink Remote. None of the sub nodes show up on my program. I am currently on PG3 3.1.23, 10x 5.59 and Yolink 0.8.41. What am I doing wrong? all 4 of the nodes show up for the key presses.
  6. wacvmd posted a topic in eisy
    I was migrating from994 to eisy. It went fine initially but after after restoring isy from a back-up, I went to restore a new a 2513U PLM. It took a while a while and while during the update the eisy shut down. After opening the administrative console I tried to restart restore plm and nothing happened. I closed the eisy and went back to running Isy. I tried doing a factory restore by clicking the button 10 times and waiting 10 minutes and when I look at the administrative console my insteon system is all there with green marks at all the devices. Any advice what to do now? Thanks: Bill Crane
  7. wacvmd posted a topic in eisy
    Does it matter which USB port you plug the plm into?
  8. I have received my new eisy and I want to upgrade from an isy 994. I am running 5.0.16c firmware on the ISY and have the Z-Wave 2100 board installed. I received the Z-Wave Dongle REV E. and never installed it. I only have 8 Z-Wave devices installed. In order to upgrade to 5.3.4 would you recommend I uninstall the Z-Wave Board, install the Z-Wave + board, or not back up Z-Wave devices in the backup? With only 8 Z-Wave devices I assume it would be easier to add them after installing Z-Wave/matter Dongle. Any help would be appreciated: wacvmd
  9. wacvmd posted a topic in eisy
    Can you use a 2412UH modem with eisy?
  10. wacvmd posted a topic in ISY994
    I need help in writing a program. I have a space heater controlled by an appliancelinc and a IOlinc controlled by a high low thermometer. If I set it up a scene the heater cycles on and off frequently. I wrote the following program: If Control 'Workshop Thermometer-Sensor' is switched On Then Set 'Workshop Heater' On Wait 10 minutes Set 'Workshop Heater' Off Else - No Actions - (To add one, press 'Action') The problem is if the sensor is still on after 10 minutes the program will not restart. Any suggestions to finish this would be greatly appreciated.
  11. wacvmd replied to wacvmd's topic in ISY994
    Thank You: I was trying to add it be adding new device, when I used the linking menu no problem. Thanks again.
  12. wacvmd replied to wacvmd's topic in ISY994
    Does it mater if I use the 2412S or a new dual band plm?
  13. wacvmd posted a topic in ISY994
    I am unable to add MorningLinc to isy. I am running 2.84. I believe when I loaded 2.84, I got the agreement form and clicked accept and a message that it was not accepted. It doesn't matter if I hold the MorningLinc button down the whole time or reset as instructions for reset. I do get a message" -200000 Node not added-failed restoring device". Any suggestions? Thanks:wacvmd
  14. wacvmd posted a topic in ISY994
    Is the morning linc module supported in ISY?
  15. Hi Michel. I've cleared the java cache and still get the error with the suggested urls.
