elSYIR not working after upgrade to OS14.3/IoX 6
I had also opened a ticket with Michel and it appears that we have resolved the issue. Evidently it was a permissions related issue. We went through a number of uninstalls and reinstalls of the plugin as well as restores of BG3 and IoX backups. It took a number of hours of elapsed time but at this point the IR functionality seems to be working. Thanks for getting back to me.
I have just upgraded my eisy to OS14.3/IoX 6. I am now getting the error message Could not connect Flirc device. Make sure device is plugged in and permissioans are set see screen capture below. I have tried unplugging and plugging the Flirc device but no luck. Everything was working fine before the upgrade. Any suggestions would be appreciated.
How to add Mini Remote to ISY without knowing device address
Please disregard the question above, I was able to find the the Mini Remote in the devices links table. Thanks for your help.
I followed your directions and have manually linked the Mini Remote to a device that has been added to AC but am not finding the Mini Remote in AC. Can you tell me where to look in AC to find it? Thanks.
I have a Mini Remote (part number2342-2) whose device address label has been destroyed. Is there a way to add this device to the ISY without knowing the device address?
Water level sensor?
I have an underground tank that holds water that is collected in a french drain that surrounds my house. I am looking for some type of sensing device that is compatible with the ISY that would generate an alert when the water in the tank reaches a certain level. Suggestions would be appreciated
Does anyone make an Insteon announcement speaker/device
Where is the "set up guide" that you spoke of?
Teken, thanks for the detailed reply.
Teken, how do you make the robot stop, pause, or emphasize a phrase / sentence?
Insteon Siren?
Does the ISY994i work with the Insteon siren, part number 2868-222. I didn't see it in the pull down list of Insteon devices. If not supported, is there another siren that would work?
Noob: Control KPL LED
As I stated in my initial post (see screen shot), that is exactly what I nm trying to do, but it is not working. I am trying to determine if I have something setup wrong or am missing something.
I am attempting to control a keypad button's LED through Isy. I have setup a scene containing only the keypad button as a responder (see attached screen clip). However, when I turn this scene "off" from either the Isy Console or an Isy program the button's LED remians on. All of the buttons on this keypad are set to "Toggle" mode. The program is as follows: Turn FR Lights Off Button Off - [ID 0003][Parent 0001] If Control 'Keypads / Kpd-Kitchen / Kpd-Kitchen - D' is switched On Then Wait 3 seconds Set Scene 'Scenes / SCN: Kpd-Kitchen Btn D' Off Else - No Actions - (To add one, press 'Action') Any suggestions at what I am doing wrong or how to resolve this would be appreciated:
mmoore99
Joined
Last visited
