ballensr
Everything posted by ballensr
  1. i don't think so because when i look at the last item in the sample then it does not have one. But i tried it and got the following: Starting HomeBridge server... undefined:20 ] ^ SyntaxError: Unexpected token ] Maybe it does not like something it found in my /rest/nodes xml... They don't all have a "property" data item.
  2. { "description": "This is an example configuration file with all supported devices. You can use this as a template for creating your own configuration file containing devices you actually own.", "platforms": [ { "platform" : "Nest", "name" : "Nest", "username" : "me@somewhere.com", "password" : "11111111" }, { "platform": "ISY", "name": "ISY", "host": "10.10.10.121", "port": "80", "username": "user", "password": "secret" } ] And if i delete the ISY part and leave Nest in the it will start. Thank you
  3. I get the following error on startup for the ISY (when i edit ISY out of the config then i have a Nest that initializes ok and will work. [iSY] Fetching ISY Devices. events.js:85 throw er; // Unhandled 'error' event ^ TypeError: Cannot read property '0' of undefined at /lib/homebridge/platforms/ISY.js:70:45 at Array.forEach (native) at /lib/homebridge/platforms/ISY.js:57:35 at Parser.<anonymous> (/lib/homebridge/node_modules/xml2js/lib/xml2js.js:459:18) at Parser.emit (events.js:107:17) at Object.onclosetag (/lib/homebridge/node_modules/xml2js/lib/xml2js.js:420:26) at emit (/lib/homebridge/node_modules/xml2js/node_modules/sax/lib/sax.js:615:33) at emitNode (/lib/homebridge/node_modules/xml2js/node_modules/sax/lib/sax.js:620:3) at closeTag (/lib/homebridge/node_modules/xml2js/node_modules/sax/lib/sax.js:861:5) at Object.write (/lib/homebridge/node_modules/xml2js/node_modules/sax/lib/sax.js:1294:29) Any ideas?
