jamesrm
  1. Hello, I had a small setup 3 years ago at a residence. Recently, I purchased a 4,000 foot finished (with 2,000 additional feet unfinished) home and have replaced nearly 100 switches and outlets with insteon products. I also have quite a few hidden door links, motion detectors, leak detectors, and have the garage door kits installed on several doors (using the walk through here)... I am trying to create the following programs and need some help: 1) I would like button 8 on my 8 button keypad links to be illuminated if any of the interior lights are on. I would like a button press WHEN the light is illuminated (so an interior light is on, somewhere) to turn off all the lights OR trigger a leaving script, which turns off the lights that are on and turns on a few lights for a limited duration. I had something like this before, but I forgot how to properly code that. 2) I read somewhere that double clicks can be used to toggle scenes. I have a kitchen scene that turns on all the lights to ON. But, it would be nice to use the same keypadlinc button to maybe toggle to a more dim scene. How do I do this? 3) I have an exterior scene with my outside lights that is also on a program to run a little after sunset until a bit before sunrise. I previously had made it that anytime a exterior light was manually turned off, the scene turned the light back on. How do I set that code up? It would be cool if a double toggle would over ride the scene, or another event could over ride it, but normally I would want that scene on at night. Thanks for the help! James
