dbb1
Everything posted by dbb1
  1. As far as filters go, wouldn't the less expensive XPPF X10 filters perform the same functionality as the FilterLincs? The only difference that I could tell between them is the pass-through outlet and higher amp rating on the FilterLinc. So in my mind, it's just a matter of application (don't need the pass-through outlet, low wattage device to filter, etc.). Whether marketed for X10 or Insteon, these filters are all operating the same way electrically, right?
  2. So things have gotten a little strange. Now that I can consistently control the Insteon 2477S from the ISY994i (after moving the ISY/PLM to the wiring closet), I moved on to see if I could access any of my X10 switch installations. The downstairs master bedroom X10 devices seem to work when programmed from the Admin Console (although I do occasionally lose the ability to control them). Other X10 switches across the house not at all. In fact many of my wired x10 switches are not working from the PalmPad I previously used to control them (RF to a plugged-in receiver, which then sent the signal onto the power bus). I can only get these lights to work by plugging in the old X10 tabletop MC460 mini controller, but even then, the mini controller has to be plugged in to the "right" outlet for that particular light to work. The X10 coupler I have been using is the SignaLinc 4816A2, which plugs into the dryer outlet. Removing it makes no difference. So, either the SignaLinc is shot, or, I've got something killing the powerline signals. Does the old X10 SignaLinc need to be replaced with something newer, that also works with Insteon, and/or do I need to start deploying FilterLincs?
  3. I came home from work today, prepared to spend the evening with all this... First thing I tried was moving the ISY and PLM up to the wiring closet, and plugging in directly to a port on the Uverse gateway. Bada bing, the 2477S is responding to both on and off commands from the Admin Console, and seems to do so reliably. So for now, it seems as if the issue has been resolved. I don't yet know if it was due to getting it on a different power leg, or moving it off of the circuit that the PC is on... Or both. Will have to give it a bit to see if it holds configuration, while I see if I can get some X10 commands to work.... Finder still doesn't automatically detect the ISY (have manually added the static IP). This seems to be a common problem I've seen lots of posts on - does it ever work for anyone? But not having it automatically detected leaves a feeling in the back of my mind that something's still not quite right. I'll pull the phase coupler a bit later, and see what impact that might have on things. Thanks again to everyone for the assist! -DBB
  4. All good info, here. Thanks, Paul, Stu, and Brian! Paul, my Insteon switches only came with a single sheet of instructions on how to install them, so thank you for the link. I do have the ISY/PLM on the same outlet as my PC; it's where all my easily accessible network gear is located, so it might be a tall order to relocate things to another point with a network drop handy. Could this also be the cause of Finder not detecting my ISY? I'll double-check the X10 plug-in coupler to see if I can tell what it is - I put it in a long time ago. I've also seen mention of a 4-tap test, but have no idea what that is. Will see if I can find more info on that. Will report back with what I find. Thanks, again, DBB
  5. I have have several X10 switches around the house, but recently got the UD ISY 994i and a few Switchlincs. I've only installed one of the 2477S switches to test. It's installed to is a single, incandescent ceiling light, and works fine. It's the remote operation of it that fails... I seem to be having communications issues. I've updated Java, etc. per the Quick Start I found online, but the Finder never picks up the ISY; I have to add it manually using its IP. The PLM shows all good in the diagnostics. From the ISY994i, I can occasionally link to and turn on the Switchlinc, but can never turn it off, due to a communication error. More times than not, though, the Switchlinc can't be reached at all, and shows a red exclamation in the console. I've only been able to find a couple of posts elsewhere that were similar, but the issues were usually due to LED or CFL loads. Is this a power line issue? Does Insteon require a phase coupler, like X10 did (I have a plug-in coupler at the electric dryer, so I wouldn't think that could be an issue). I've also seen posts on firewall issues, but the WiKi has no content for Windows Firewall, so I'm not sure what, if anything needs to be added/opened up there. I also see that Avast creates issues - I'm running Nortons AV, and have not seen anything relating to that. The ISY/PLM is plugged into a Cisco switch in my home office, which runs back to the UVerse residential gateway upstairs. Was hoping for more of a plug and play setup with this and more stability than what X10 gave, but would welcome any insight someone might have. Thanks, DBB
