JJP%^Houston
Everything posted by JJP%^Houston
  1. Admin console indicates sunset time and sunrise time, and the current time is after sunset but before sun rise. Raised garage door and observe KPL button illuminated ('07.2 Den Bk A Patio Lanterns / 07.2 Den Bk G Garage Door' is not Off) Ran IF. No result.
  2. Forgot to mention, the KPL button indicating the garage door up/down, illuminates properly, off down, illuminated open. This is the program Garage Door w/lights at nite redone - [iD 001F][Parent 005F] If From Sunset To Sunrise (next day) And Status '07.2 Den Bk A Patio Lanterns / 07.2 Den Bk G Garage Door' is not Off Then Wait 2 seconds Set '17.1 Garage A Breezeway' On Set Scene 'Common 8 button Scenes / Breezeway' On Set '21 Garage CFL SE4 inside' On Set Scene 'Garage SE inside' On Set Scene 'Den Back 8 Left / Den Bk 8 Garage + Shop Off' On Set '33.1 Patio A S. Yard Floods' On Set Scene 'Common 8 button Scenes / Back Yard Floods' On Else Wait 2 minutes Set '17.1 Garage A Breezeway' Off Set Scene 'Common 8 button Scenes / Breezeway' Off Set '21 Garage CFL SE4 inside' Off Set Scene 'Garage SE inside' Off Set Scene 'Den Back 8 Left / Den Bk 8 Garage + Shop Off' Off Set '33.1 Patio A S. Yard Floods' Off Set Scene 'Common 8 button Scenes / Back Yard Floods' Off
  3. For no apparent reason, this program stopped working. Left and worked properly, returned and has not worked since. From sunset to sunrise and KPL button (status not off) becomes illuminated (which is an indication that the Insteon Garage door status device indicates garage door was opened) wait 2 seconds, designated lights come on, wait 2 minutes, those designated lights go off. I tried the following; Click run-then, run-else in program and it responds accordingly. Lights turn on and goes off in 2 minutes Disabled program and rewrote it. New program not working either. Restored 8 button dual band KPL containing the garage door indicator . No effect, not working. Unplugged isy for 2 minutes. No effect, not working. What next? Also when the garage light (a designated light in referenced program) is switched on manually with a insteon device during the day the this light will go off after 2 minutes; I have to turn it on and then stays on until I turn it off. How is this glitch solved?
