mgiron10
Everything posted by mgiron10
  1. If Status 'Fireplace-Sensor' is On Then Set 'Fireplace-Relay' On Else Set 'Fireplace-Relay' Off Thank you,
  2. I am having a little bit of an issue with my Heatilator automation. - I have changed out my wall switch to a momentary switch - Under my fireplace I patched the wires from the switch to go back to the IOLinc sense/ground inputs - I connected the fireplace wires to the IoLinc No/Com inputs. - I have made both nodes Latching with a Momentary hold time of 10 seconds. My issues is that I can only turn off the fireplace with the momentary switch but not on. I can turn on and off the fireplace from the Admin Console. Any suggestions?
  3. I am having a little bit of an issue with my Heatilator automation. - I have changed out my wall switch to a momentary switch - Under my fireplace I patched the wires from the switch to go back to the IOLinc sense/ground inputs - I connected the fireplace wires to the IoLinc No/Com inputs. - I have made both nodes Latching with a Momentary hold time of 10 seconds. My issues is that I can only turn off the fireplace with the momentary switch but not on. I can turn on and off the fireplace from the Admin Console. Any suggestions?
