LDWelton
  1. You should also be able to create an applet in IFTTT. Nest--->IFTTT(maker)---->ISY Portal triggering a program to turn off your fan and your lights on. Never tried it myself so it may not be possible, but should work. ?
  2. LDWelton replied to smokegrub's topic in UD Portal
    All is good here also. Thanks UDI, didn't look forward to doing these things manually
  3. LDWelton replied to smokegrub's topic in UD Portal
    Also having trouble with Google Home. Getting "encountered unknown error for spoken"
  4. Well everything functioned normally this time, so I dunno what happened. Thanks
  5. That's what happened to me. I did an update and it removed my room assignments in the GH App??!!? I'll try to do another update today and see what happens.
  6. I tried this yesterday and it worked. However it removed all my room assignments in google home. Do we have to set the room in portal also? Thanks Lloyd
  7. So I have found a more elegant way to accomplish voice control of my locks. It no longer requires keypadlinc buttons and scenes. I wrote a program that is not enabled: SDControl - [ID 0013][Parent 0001][Not Enabled] If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Set 'SideDoor' Unlock Else Set 'SideDoor' Lock then in the portal under IFTTT Connectivity I chose program, for unlock I chose "Run Then" and of course for lock "Run Else". Then as normal made applets in IFTTT with Google Assistant as IF and Webhooks in THAT. Much Simpler!
  8. So I created A work around to accomplish this. In Admin console, I made two scenes (lock & Unlock) each with a keypad button set as responder. I also made two programs (again lock & unlock) if Button A (or Button B ) is on then lock (or unlock) the door and turn off the scene with Button A (or Button B ). Then went into the portal and used IFTTT option for the two scenes(again lock & unlock) to turn on. Finally went into IFTTT and made applets using Google Assistant as IF and Webhooks as That. Bing, Bang, Boom It Works!!!!! I can now control my locks using my voice. Clear as mud right
  9. Thanks Jimbo, bummer Synchronize had me scratching my head too??? But Thanks Stu. Thanks again. Lloyd
  10. So I set up my Weiser ZWave lock in the portal to use with my Google Home. I un-linked my account and re-linked several times in Google Home app but the lock does not appear in the list of devices. I checked and ISY can communicate with lock and I can control it through MobiLinc App (Through portal). Is this a known issue? Can you think of anything I can check? Thanks for any Help you can provide. Lloyd
