HEPennyPacker
  1. That was it! I did a restore device on the KPL and it started to work for scenes which included a remote device. The first sign that this was the fix was that when I pushed a KPL button the little green LED flashed where it was not doing that before. Thank you much, Techman!
  2. No - the B button doesn't light when I flip on the togglelinc. And vice versa, the lights controlled by the togglelinc don't light when I push the B button on the keypad. I tried creating a different scene with another lamp and the keypad and it too did not work. I also created a scene with the light hardwired into keypad. That worked. But no scenes are working which are remote from the keypad. The other thing is that when I have the Event Viewer open on level 3 logging nothing happens when I push the keypad buttons. There are no events logged when pushing KPL buttons. Is this normal? Also - when I run a scene test through the ISY console, the lamp turns on and the admin console says that the button is ON but it is not lit. I'm totally confused. Thanks
  3. Appreciate the quick feedback. Clearly something is wrong in my setup. I've added the dimmer switch and the keypad B button to the a new scene. I've disabled all other programs. When I turn the scene on from the admin console, it turns on and shows the dimmer switch as on and keypad B as on. When I look at the keypad switch, the B button is certainly not lit. The reason I'm trying to do this is because the lights in question which the dimmer controls are not visible from where the keypad is which is why I want the indicator. I'm attaching a picture of the scene setup and the keypad which clearly shows no button lights lit! Thank you again!!! imgupload10.tiff
  4. What does it mean to add the KPL button to the scene as a controller/responder? It only allows me to add it as either a controller OR a responder but not both. Thanks!
  5. I attached images of the scenes and programs. Not sure if there is a better way to export this information. Thank you! imgupload1.tiff imgupload2.tiff imgupload3.tiff imgupload4.tiff
  6. Yes and No. I have two scenes. One scene the keypad button is a controller to the lights. In another scene, the keypad button is a responder with no controller. The program then triggers the scene. (I tried to copy an example I found online to control keypad lights). Thanks
  7. I am unable to get a KeyPad Linc LED to reflect the status of a scene even though the UD Administrative Console says the LED is on. Would love some help on why I can't get the LED lit with the scene! I've tried turning the scene on from MobilLinc Pro on my phone and by flipping the dimmer switch directly to no avail. Thank you! 2A.95.FA is a 2334-2 KeypadLinc Dimmer 5 Buttons v.43 - in Admin Console it's current state is 'On'. LED off brightness is 0, LED on brightness is 7. When looking at the Keypad however only the 'Off' button is lit. This is device is called "Island Lights" and the keypad buttons are called "Island Keypad - Scene A - D" 23.35.89 is a 2466D ToggleLinc Dimmer v.41 - in Admin Console it's current state is 'On'. This device is called "Basement Playroom Lights" "Basement Playroom Scene" has Island Keypad - Scene B as a controller and Basement Playroom Lights as a responder "Basement Playroom Scene LED" has Island Keypad - Scene B as a responder Program 'Any "Basement Playroom Scene" Devices On': If Status 'Basement Playroom Lights' is not Off Then - No Actions Else - No Actions Program 'Basement Playroom Scene Update LED' If Program 'Any "Basement Playroom Scene" Devices On' is True Then Wait 2 seconds Set Scene 'Basement Playroom Scene LED' On Else Wait 2 seconds Set Scene 'Basement Playroom Scene LED' Off Event Log: Mon 09/14/2015 11:10:00 PM : [FileOpen ] Open failed for [/CONF/INTEGER.VAR] ® Mon 09/14/2015 11:10:00 PM : [FileOpen ] Open failed for [/CONF/STATE.VAR] ® Mon 09/14/2015 11:10:15 PM : [iNST-TX-I1 ] 02 62 2C 35 89 0F 11 FF Mon 09/14/2015 11:10:15 PM : [iNST-ACK ] 02 62 2C.35.89 0F 11 FF 06 LTONRR (FF) Mon 09/14/2015 11:10:15 PM : [iNST-SRX ] 02 50 2C.35.89 2B.95.61 27 11 FF LTONRR (FF) Mon 09/14/2015 11:10:15 PM : [std-Direct Ack] 2C.35.89-->ISY/PLM Group=0, Max Hops=3, Hops Left=1 Mon 09/14/2015 11:10:15 PM : [D2D EVENT ] Event [2C 35 89 1] [sT] [255] uom=0 prec=-1 Mon 09/14/2015 11:10:15 PM : [ 2C 35 89 1] ST 255 Mon 09/14/2015 11:10:15 PM : [D2D-CMP 0015] STS [2C 35 89 1] ST op=6 Event(val=255 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true Mon 09/14/2015 11:10:15 PM : [D2D-CMP 0007] STS [2C 35 89 1] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false Mon 09/14/2015 11:10:15 PM : [D2D-CMP 0006] STS [2C 35 89 1] ST op=3 Event(val=255 uom=0 prec=-1) > Condition(val=0 uom=0 prec=-1) --> true Mon 09/14/2015 11:10:15 PM : [D2D-CMP 0005] STS [2C 35 89 1] ST op=6 Event(val=255 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true Mon 09/14/2015 11:10:17 PM : [iNST-TX-I1 ] 02 62 00 00 13 CF 11 00 Mon 09/14/2015 11:10:17 PM : [iNST-ACK ] 02 62 00.00.13 CF 11 00 06 LTONRR (00) Mon 09/14/2015 11:10:17 PM : [D2D EVENT ] Event [2A 95 FA 4] [sT] [255] uom=0 prec=-1 Mon 09/14/2015 11:10:17 PM : [ 2A 95 FA 4] ST 255
