ArCaDe
  1. Thanks for the response Stu.Firmware is 3.3.10, UI is 4.5.4 (due to the expired SSL issue using the workaround). I remove & re-added the tstat & now it shows up as 3 devices, Main, Cool, & Heat. I was finally able to get the program to work. Im currently testing it & it worked twice. the last time it didnt & when I checked the admin console it had an error that it couldnt communicate with the appliance module. I get that error alot in the console but everything works otherwise. Are there any tips to resolve communication issues with devices? I dont want the AC to turn off & leave the fan on. In my last test the AC turned on but the fan didnt & thats when I saw the error in the admin console. When the AC turned off the appliance module did turn off. Below is the program I created. I tweaked it to leave the AC blower fan on for X mins after the setpoint is reached & then turn the blower fan & appliance fan both off. SO far in testing its working as expected. TurnOnFanWhileColling - [iD 004F][Parent 0039] If Status 'Insteon Thermostat - Cool Ctl' is On Then Set 'FanApplModule' Fast On Else Set 'Insteon Thermostat - Main' Fan On Wait 1 minute Set 'FanApplModule' Fast Off Set 'Insteon Thermostat - Main' Fan Auto
  2. Hello all, I have a ISY99i\Pro with an Insteon Thermostat 2441TH. I want to write a program to turn on an appliance module when the thermostat is calling for cool. The program is created but nothing occurs when the AC kicks on & off. I checked the logs & dont see anything that reports the thermostat is calling for cool. Im running the latest ISY99i firmware. Is this a feature that would only work with the newer ISY models? I basically want to have 2-3 modules connected to fans, when the thermostat calls for cool the modules will turn on & power the fans. When the thermostat stops calling for cool the fans will power off. Any clue what I can do to get this working. Sorry if I posted in the wrong forum.
