jtdohert
Everything posted by jtdohert
  1. The manual for the 2441TH thermostat states it can be remotely put on/off hold. While I can physically do this at the thermosat, and can remotely control virtually all other functions via the ISY Admin Console and (and Mobilinc too), I can't see any option to set a temperature and put the thermostat on hold, or take it off of hold and resume program auto mode. Can anyone else weigh in?
  2. I have written a program to turn on the lights about 1/2 hour before sunset and off later in the evening. The only check is Time is Sunset - 30 minutes, I don't care about the state. In the same "Then" clause I turn on 4 different devices, 2 of which are Insteon bulbs (2674-222) and (2672-222). While the other 2 devices (a wall switch and a plug in module) work consistently every time, the bulbs do not. Sometimes 1, the other or both will work randomly. The ISY log shows the commands were sent, the devices did not respond (says the human). Has anyone run into this? The odds of 2 different bulbs in 2 different lamps being defective is slim. Running the android mobilinc app or the Console on the PC (which goes through the controller) to manually turn on the devices works every time.
