Hydroid
Everything posted by Hydroid
  1. Hydroid replied to Hydroid's topic in Google Home
    MWareman: Yes, my ISY Cat is Device... bmercier: Did the sync, and all working fine now - Thanks! BTW, I have switches assigned as switches and receptacles as receptacles and where the device (switch or receptacle) is dimmable, they work just fine when asking to dim - so they don't need to be a light... Thanks for all the help [emoji4] Sent from my iPad using Tapatalk
  2. Hydroid replied to Hydroid's topic in Google Home
    I changed the switch designation to light and unlinked, then relinked the mini to update the devices. No change: On/Off is fine, but dimming doesn't work. I have a lamp plugged in to a receptacle that is dimmable via the ISY app, so I assigned it as a receptacle to the mini. Same thing, On/Off works but dimming does not. I see from other respondents below that others are having the same issue. I guess On/Off will have to do.... Thanks for trying to assist [emoji4] Sent from my iPad using Tapatalk
  3. Hydroid replied to Hydroid's topic in Google Home
    The light is controlled by a 2577d Dimmer Switch, so I assigned it as a switch... Sent from my iPad using Tapatalk
  4. Hydroid posted a topic in Google Home
    Received a Google Mini for Christmas. Purchased and installed the Portal module on my ISY994i and linked the two together successfully. I have some issues with room naming / device naming that I see others are having - so I'm following those threads. One issue I don't see - and sorry if I missed it - is dimming. On one of the final screens of the install process, and in the wiki, it states that dimming is possible by saying something like, “Hey Google, set family room light to 50%”.... Well, I've tried every variation of that I can think of and my mini always replies with, “It looks like those lights haven't been set up yet, just open Google Home control....” - even though the mini will turn them on or off without issue.... Is it possible to dim lights? Note that the lights in question are connected to an Insteon 2447d dimmer switch, and dimming works with the UDI applet on my PC's and iPads.... Thanks, John.
  5. I have an older 2440 (V1.0) and tried virtually everything I'd read here - and via Google search. Move it closer to the PLM, move it far away from the PLM, move it near a switch, hold it up in the air, change angles while holding it.... You get the idea. Nothing worked, I'd always get the '010101’ icon and some type of error message. Mostly out of desparation, I tried cleaning the contacts with fine sandpaper, then isopropyl alcohol and then installed 4 brand new alkaline AAA's - even though the batteries in the 2440 were fairly new and functioned fine... BINGO! Linked up right away with no issues - and works perfectly. I'm sure glad I came upon your post and thank you for the information!
  6. Well there you go. I didn't know that the program only executes at the 'from' and 'to' times. As a test, I changed the from time to a few minutes into the future, saved the changes, and sure enough, it started cycling.... Also didn't know about the right clicking and running the various parts of the program... Thanks very much for the help! Regards, John.
  7. I'll state right off the bat that I'm new to the ISY-994i.... I'm trying to get a lamp to cycle on for and hour, then off for two hours, and then repeat, during the day between 8:00am and 10:00pm. Incase you're wondering, it's the lamp for a scentsy fragranced wax pot... As a test, i came up with this program which I titled 'Test' to cycle the lamp on and off every 10 seconds - so I could watch it and not have to wait for hours. Then, I planned on just changing the 'wait' values to the desired time. The lamp is plugged into a 2635-222 On/Off Module titled 'Lamp' Program - 'Test': If From 08:00:00AM To 10:00:00PM (same day) Then Set 'Lamp' On Wait 10 seconds Set 'Lamp' Off Wait 10 seconds Run Program 'Test' (If) Else - No Actions - (To add one, press 'Action') I click 'Save changes' and then exit the Administrative Console, thinking that the lamp will start to cycle on then off every 10 seconds because it's about 1:00PM now which is within the 8AM to 10PM 'If" time, but nothing - the lamp remains off. I know the module is being seen by the ISY, because if I use the manual ON and OFF buttons from within the console, it does respond. What am I missing? Regards, John.
