gapon0
Everything posted by gapon0
  1. hello, need suggestion have hydronic heating, with 8 zones, want install aeon multi sensor in each room, and control all over Ipad or android etc. don't want put thermostat in each room. just sensor. so don't know solution wrote on many forums no body cant give idea. in theory it easy, but maybe some one already did it. it easy if thermostat can read sensor then no problem, but don't know if any thermostat can read remote z wave sensor. please let me know if some one have suggestion. thanks you
  2. so any suggestion?
  3. hello, some how I miss your respond. that is another issue I need use probably just any relay as insteon or zwave to control speed, and I am stuck with remote sensor, so I installed multisensor 6 in the room, so which thermostat can reed temperature from the sensor.
  4. Hello, can you help me understand, I have Multisensor 6 installed in the room, so which thermostat I need to chose that can pick up temperature from multisensory 6, as I want put thermostat in boiler room, and all HVAC control will be from IPAD or so. i need find solution for control HVAC with only multisensor in the room. Any ideas will be so much appreciated. Thank you
  5. Hello, can you help me understand, I have Multisensor 6 installed in the room, so which thermostat I need to chose that can pick up temperature from multisensory 6, as I want put thermostat in boiler room, and all HVAC control will be from IPAD or so. i need find solution for control HVAC with only multisensor in the room. Any ideas will be so much appreciated. Thank you
  6. hello, just find some picture from fan coil, it is regular fan coil device that has fan with 3 speed, so 4 wires, neutral and 3 loads, 220v. So I need solution how control it for ventilation and for heating or cooling, so need to control it from thermostat insteon or any another, but don't know how. thank you for any advise
  7. Thank you for help to understand, I have another question maybe you can help also. I have ventilation system/ air conditioner that has fan with 3 speed, with 3 wires for speed, how I can control it, is it normall Insteon thermostat has 3 speed fan, and relay for it or I should put separate relay to control speed? thank you. also that fan not 110v, it is 220v. need solution.
  8. what about temperature sensor can i use any zwave sensor, still confusing
  9. hello, need help with thermostat solution, here is idea. in the room want use in wall Ipad docking stantion, to control everything, don't want install thermostat, what just temperature sensor, and thermostat install at HVAC room, that will receive information from sensor. how, I can do it, which system to use, how I can connect it all to ISY. please advise, I just nee understand how to run it, or maybe some one already did that system. Thank you
