rkuzyk
  1. I'm having issues getting Homebridge working. Receiving the following ... Loading 1 platforms... [Wink] Initializing Wink platform... Loading legacy platform Wink [Wink] Fetching Wink devices. Loading 0 accessories... response in http: {"data":{"error":"invalid_grant","error_description":"This client is not permitted to use the password grant type"},"errors":["invalid_grant: This client is not permitted to use the password grant type"],"pagination":{},"error":"invalid_grant","error_description":"This client is not permitted to use the password grant type"} response in http: SyntaxError: Unexpected end of input at Object.parse (native) at IncomingMessage.<anonymous> (/usr/local/lib/node_modules/homebridge-legacy-plugins/node_modules/wink-js/index.js:62:19) at emitNone (events.js:72:20) at IncomingMessage.emit (events.js:166:7) at endReadableNT (_stream_readable.js:905:12) at doNTCallback2 (node.js:450:9) at process._tickCallback (node.js:364:17) raw message /usr/local/lib/node_modules/homebridge-legacy-plugins/platforms/Wink.js:87 for (var i=0; i<devices.data.length; i++){ ^ TypeError: Cannot read property 'data' of undefined at /usr/local/lib/node_modules/homebridge-legacy-plugins/platforms/Wink.js:87:34 at /usr/local/lib/node_modules/homebridge-legacy-plugins/node_modules/wink-js/index.js:198:7 at IncomingMessage.<anonymous> (/usr/local/lib/node_modules/homebridge-legacy-plugins/node_modules/wink-js/index.js:69:7) at emitNone (events.js:72:20) at IncomingMessage.emit (events.js:166:7) at endReadableNT (_stream_readable.js:905:12) at doNTCallback2 (node.js:450:9) at process._tickCallback (node.js:364:17) Here's what my config.json file looks like ... { "bridge": { "name": "Homebridge", "username": "CC:22:3D:E3:CE:30", "port": 51826, "pin": "031-45-154" }, "description": "This is an example configuration file with all supported devices. You can use this as a template for creating your own configuration file containing devices you actually own.", "platforms": [ { "platform": "Wink", "name": "Wink", "client_id": "YOUR_WINK_API_CLIENT_ID", "client_secret": "YOUR_WINK_API_CLIENT_SECRET", "username": "your@email.com", "password": "WINK_PASSWORD" } ], "accessories": [ ] } I'm using all the default values from the config-sample.son file. Is that right? Any help would be appreciated.
