BONeil
Everything posted by BONeil
  1. @gzahar That worked!! Thank you
  2. EISY 5.8.3, I recently reset my zwave network and dongle. Everything is back and good, locks respond fast and a heal takes under 2 minutes without any retries or comm problems in Event Viewer. Connection speed is good and nodes seem well placed. However, my two Schlage BE469ZP no longer notify the EISY when they are manually unlocked, so their state in the ISY never changes when it is manually unlocked. This did work prior to the reset, but I have no idea how to get it working again since for all intents and purposes, Zwave is working well and fast with little latency. I tried exclude\include, zwave compatability mode, heal the world, update neighbors, update with interview, detect button presses on\off. The locks both read as S2 access. Also, I did add a ULock zwave recently which shows up as S2 Access [S0] if the secure inclusion parameters matter in this instance. The ULock DOES notify the EISY when it is unlocked, so not a problem with the overall Zwave network as far as I can tell. One concerning thing is I see is that they show up as 'Interview Not done' and I have interviewed them numerous times. In X-Ray -> [DH All Devices]: Devices list: 1 Interview Not done --> assuming EISY radio since other devices 2 Interview done --> GE Enbrighten 3 Interview done --> GE Enbrighten 4 Interview done --> GE Enbrighten 5 Interview done --> ULock 6 Interview done --> GE Enbrighten 10 Interview Not done --> Schlage1 14 Interview Not done --> Schlage2 Lastly, the locks were paried next to the ISY and moved to their location after paring which was the conventional wisdom a few years back, not sure that is still the case. Let me know your thoughts on anything I've missed and any ideas to further troubleshoot.
  3. It seems all of my programs have been disabled after upgrade. Kind of a surprise to see. Now I need to remember which ones were intentionally disabled.... Update: I enabled the ones I need, rebooted and they are all disabled again. Please advise.
  4. Got to the bottom of this one while I was eating lunch, but figured I'd document if anyone else runs into it. Nothing to do with the PG3 module what so ever. Originally, I was using homebridge to access Elk through the ISYMaker add-in. When I migrated to the EISY, I had to change the service on Homebridge to the dedicated Elk add-in. Turned off homebridge and now it's working as expected. Something with the Elk module on Homebridge caused it to go awry. I migrated my HomeKit to Home Assistant and that seems to play much better with Elk along with the EISY.
  5. Before I upgraded to EISY\PG3, I had an Elk automation that would wake my PC with Networking WOL when the Elk motion sensor was triggered in my office. I added the new WOL Polyglot and that seems to be working fine independent of the automation. After upgrading and adopting PG3, I noticed, 2 of my 3 motion sensors are no longer sending violated events. Anyone else see this?
  6. I found that pressing the pair button 3 times in quick succession adds the Aeotec Energy Meter to the EISY properly. One press added a single useless node.
  7. Thanks Mr Bill, a reboot is fine. Not looking for full continuity of uptime. Just make my reference of the old system easier. Actually, to add to this, I'd like to find a way to keep the ISY around after step 4 in case I need to refer back to a program of variable.
  8. Getting ready to flip the switch here. I have quite a few devices both insteon and zwave, along with a ton of Elk sensors and automation that is going to break. Ideally, I would like to have both systems online at the same time to compare the programs against each platform. My hopeful process is outlined below, but would like to understand caveats with the bridges (insteon PLM, Zwave, Elk etc) while they are in an 'offline' or disconnected state during comparison. This is based on the migration guide. 1. Assign unique IP addresses for EISY and ISY 2. Restore backup on EISY, keep PLM on ISY, do not attach zwave\matter radio to EISY yet 3. Do the compare, fix the programs and variables with two admin consoles 4. Decomission ISY 4.a Power down ISY 4.b attach PLM and Zwave radio to EISY 4.c Configure settings in EISY to begin using PLM and ZWAVE 4.d Remove ISY from portal
  9. BONeil replied to BONeil's topic in eisy
    That's reassuring, thank you. I can deal with some temporary pain and can fix most problems, but lingering problems on critical systems (locks, alarm, etc) are a non-starter for the near term. I've had HA for 15ish years and my wife and I have grown to be somewhat uncomfortable without it. I am hearing a lot of Polisy to Eisy migrations, but I think those are far less impact from 994i -> Eisy since the architecture changes a bit. In particular, I am still trying to figure out how I will revisit my extensive library of Elk automations (it appears Elk moved to PG3) so I will have to touch each automation. Just time I didn't allocate for this weekend and probably explore a way to incrementally migrate instead of ripping a band-aid off. Possibly using Homeassistant as an abstraction to make the transition seamless.
  10. BONeil replied to BONeil's topic in eisy
    To be honest, I got a bit gun-shy. I have a pretty complicated setup (~100 insteon devices, ~60 zwaves, ~60 Elk sensors and a bunch of Polyglot 3 nodes). Tons of programming that works very well. I've seen a bunch of posts about the reliability and getting door locks working and that has me worried.
  11. BONeil posted a topic in eisy
    I decided to roll back from a 994i to Eisy migration (not meeting WAF). I did not change anything on either system. I read in the users guide: In the migration I followed the procedure where I backed up the Z-Wave network before I did the ISY Backup. Then I used the ISY backup to restore on the EISY. Since some Z-Wave operations are one way, I want to make sure I understand this clearly as my action back on the 994i; Can I just use the Z-Wave -> Restore tool, or do I have to restore the entire ISY via File -> Restore ISY, File -> Restore Devices? Thank you
  12. I know with enabling 'rooms' in Echo I can tell Alexa to 'Turn on the lights' and based on the room\echo association, it will turn on only the lights in the room associated with that particular Echo I gave the command to. Can I do this with other devices? For example, I have reading lamps in my living room and office. I would like to be able to say "Alexa, turn on the reading lamp" and turn on only that reading lamp in the same room as the Echo. In the portal I noticed it does not allow you to add devices with duplicate spoken names.
  13. Can you unhide the SSID, join the network, and then hide it again? It shouldn't impact your already connected devices.
  14. The wireless function of Insteon should bridge across phases where the powerline protocol gets isolated. If you have older switches like the ToggleLinc that only support powerline communication, you can bridge them with a LampLinc or On\Off module by finding an outlet on the same circuit. If you're starting out and buying new, this shouldn't be a problem because I think most new wired in devices are dual protocol.
  15. I just got rid of my last 2 wire dimmer and tried every type of dimmable LED with it, they all flicker like mad. Thankfully I'm totally off incandescent now. I believe I bought mine back in 2010.
  16. Here is my zwave info And I am just noticing this - Zwave node 19 is a PC controller that I used to move my topology to when I upgraded to the 500 series radio. I thought I had moved ownership back to the ISY. I am not using this node in anyway, and I can remove it, but I want to avoid having to redo enrollment across the board. After removing the Z Stick I am able to see the repair links options again. Still missing the options and user reporting for the lock however. Might try and rejoin tomorrow.
  17. I have two issues that I believe may be related to 5.2.0; 1. BE469ZP is missing options and is not reporting user codes. I have a thread here with some log output on the enroll\unenroll process that I performed several times and got consistent results; 2. In regards to Blueman2's post, I am not seeing 'Repair Links' when I right click on the zwave device and go to the zwave menu.
  18. There's two homebridge ISY plugins; homebridge-isy-js which is no longer developed and the for homebridge-isy which is actively developed but is lacking some features that exist on isy-js. Personally I think they will always be lacking. Both of the plug-ins seem to have a tough time with i/o linc garage door openers. I ended up ditching the i/o linc stuff and went with the MyQ module and direct integration to homekit and polyglot to manage the ISY integration.
  19. I did a third unenroll\enroll for the lock one last time to make sure I'm not missing anything, below is the output of the lock. While it seems to be responding to config changes, lock\unlock commands and battery level, it is not reporting user numbers when the pin is entered. (and I still don't get the options UI) The enrollment process also looks like something is off with lots of failed lines. This process was done with the lock less than a foot away from an unobstructed ISY. Mon 09/28/2020 02:13:45 PM : Listening for Z-Wave devices to add to the network Mon 09/28/2020 02:13:48 PM : Z-Wave device detected, retrieving info 2 Mon 09/28/2020 02:13:48 PM : Z-Wave device detected, retrieving info 3 Mon 09/28/2020 02:13:56 PM : Z-Wave device detected, retrieving info 5 Mon 09/28/2020 02:13:56 PM : Adding Z-Wave devices stopped Mon 09/28/2020 02:13:57 PM : Z-Wave device detected, retrieving info 6 Mon 09/28/2020 02:13:57 PM : Exchanging data with secure Z-Wave device 35 of type 4.64.3 Mon 09/28/2020 02:13:57 PM : Adding secure Z-Wave device Mon 09/28/2020 02:14:09 PM : Adding ISY node(s) for new Z-Wave device 35 type 4.64.3 Mon 09/28/2020 02:14:18 PM : Adding additional nodes for new Z-Wave device 35 Mon 09/28/2020 02:14:59 PM : [ZW-TX-FAILED] enc=Ok uid=35.0 cmd=0x71.04 NOTIFICATION Mon 09/28/2020 02:15:06 PM : [ZW-TX-FAILED] enc=Ok uid=35.0 cmd=0x71.04 NOTIFICATION Mon 09/28/2020 02:15:13 PM : [ZW-TX-FAILED] enc=Ok uid=35.0 cmd=0x71.04 NOTIFICATION Mon 09/28/2020 02:15:26 PM : [ZW-TX-FAILED] enc=Ok uid=35.0 cmd=0x71.04 NOTIFICATION Mon 09/28/2020 02:15:33 PM : [ZW-TX-FAILED] enc=Ok uid=35.0 cmd=0x71.04 NOTIFICATION Mon 09/28/2020 02:15:41 PM : [ZW-TX-FAILED] enc=Ok uid=35.0 cmd=0x71.04 NOTIFICATION Mon 09/28/2020 02:15:48 PM : [ZW-TX-FAILED] enc=Ok uid=35.0 cmd=0x71.01 NOTIFICATION Mon 09/28/2020 02:15:54 PM : [ZW-TX-FAILED] enc=Ok uid=35.0 cmd=0x71.01 NOTIFICATION Mon 09/28/2020 02:16:01 PM : [ZW-TX-FAILED] enc=Ok uid=35.0 cmd=0x71.01 NOTIFICATION Mon 09/28/2020 02:16:08 PM : [ZW-TX-FAILED] enc=Ok uid=35.0 cmd=0x71.04 NOTIFICATION Mon 09/28/2020 02:16:15 PM : [ZW-TX-FAILED] enc=Ok uid=35.0 cmd=0x71.04 NOTIFICATION Mon 09/28/2020 02:16:23 PM : [ZW-TX-FAILED] enc=Ok uid=35.0 cmd=0x71.04 NOTIFICATION Mon 09/28/2020 02:16:51 PM : [ ZW035_1] BATLVL 100 (uom=51 prec=0)
  20. Converting to decimal did the trick. Thank you!
  21. Steps to set parameter = Enter 10 in the parameter number box, Enter 7 in the Value box, hit Set Configuration.
  22. I do not. And I have two BE469ZP locks added at different times, neither has the options button like the BE469 did. I excluded and then re-added one and I still did not get the options button.
  23. This is what I get from event viewer when I attempt to write Parameter 10 value 7 Sun 09/27/2020 10:12:22 AM : [ZWAVE-TE ] [70/04] CC=0x70 cmd=0x04 [0A0107] ACK,AUTO,EXPLORE To=0x1E Sun 09/27/2020 10:12:22 AM : [ZWAVE-TX ZW030_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x1E Sun 09/27/2020 10:12:23 AM : [ZWAVE-RX ZW030_1] [98/80] Security Nonce Report - nonce=[7FE7A86EBB92E93E] ACK,AUTO,EXPLORE From=0x1E And I can write and verify 4 digit user codes successfully. After which I deleted all the user codes, tried the parameter update again, assigned user 1 a 7 digit code and the lock still won't accept anything past 4 digits on the keypad.
  24. Yeah, did all the basics, restarted the console, the ISY, cleared the Java cache.
