GACSALY
  1. What new new harmony device did you add? I am stuck in the same place. When I press a remote button I see in the Event Viewer an event referencing an IR button like: [n001_irbutton_106] But I don't see any node created nor a way to reverence this button press in a program.
  2. I have been using the xxx for years to monitor my spa temperature with the ISY (the external sensor soldered to the internal pins) and it works well, BUT the first sensor lasted about 1 year then failed. The next one I embedded in an epoxy bulb and it lasted two years. Before I get another probe and try a better seal, I want to check out any other options: 1) Has anyone else had this sensor life issue? Any better ideas? 2) Has anyone actually tried the CAO Tags temperature probe to ISY with a pool or hottub (water with sanitizer)? 3) My spa (Dimention 1 with D1 Spa Connect) HAS A BUILD IN TEMPERATURE MONITOR WITH WIFI. It only reports the temperature to the iphone app (in.touch world) but it has no alerts or emails or logging. Has anyone interfaced this to an ISY? 4) Have any better options for pool/spa temperature monitoring become available? THANKS!
