KYnewbie
Everything posted by KYnewbie
  1. I had to unplug the PLM to get to the sticker so my schedules should run tonight and I will update you tomorrow. I really appreciate your help.
  2. Thanks for the reply. Answers are above.
  3. Not sure where to start so here goes. Have a couple simple on/off programs that turn on lamps controlled by some 2472D, 2663-222 and a couple LampLinc's. Program is, on at X time for 7 listed devices and then off at X time for the same 7 devices. Sometimes 5 of the 7 will turn on, next night could be 6 of the 7 will turn on. Sometimes 4 will turn off, sometimes 6 will turn off. Very random. My 2477D's that are set on schedules work without any errors, just seems to be the outlets and LampLinc's. Not sure if this is related but the admin console seems to take a couple minutes to load and it never holds the IP of my ISY994 which I have to add each time. Wondering if upgrading to the EISY would fix the issue, but hate to spend the money if the problem is all my outlets. 994 v.5.0.14 Any help or advice would be appreciated.
  4. Thanks Techman I ended up having to replace the 2486. After factory resetting it and moving it to different circuits, it acted the same.
  5. I recently installed a 2477D next to my 2486 (v45) and now every time any switch on that circuit breaker gets turned off or on, the 2486 shuts off (all lights go off) for about 2 seconds then comes back on. There are about 5 - 2477D's and 3 - 2477S's on that circuit breaker. Even when I press one of the buttons on the 2486, its shuts off for the 2 seconds but does control what I have the button programmed for. Any ideas? Switch going bad? Could be a neutral or ground not connected properly?
  6. When I installed all my devices, I made a list of each switch, where it was going to be installed and the insteon ID #. Just add them to the system all at once. When you get back to the computer, you will have a long list of ID#'s and no idea where they are in the house. Break out the list and label each switch. Good Luck
  7. KYnewbie replied to KYnewbie's topic in ISY994
    It works!! :mrgreen: Thanks so much to everyone who helped me figure it out. I started from scratch by deleting the program and scene. This is what I ended up with: Bath Room Light - [iD 0004][Parent 0001] If From 11:32:00PM To Sunrise - 1 hour and 10 minutes (next day) Then In Scene 'Bath Light Night Time' Set 'Master Toilet Light' 35% (On Level) In Scene 'Bath Light Night Time' Set 'Master Toilet Light' 2.0 Sec (Ramp Rate) In Scene 'Master Toilet Light' Set 'Master Toilet Light' 35% (On Level) In Scene 'Master Toilet Light' Set 'Master Toilet Light' 2.0 Sec (Ramp Rate) Else In Scene 'Bath Light Night Time' Set 'Master Toilet Light' 100% (On Level) In Scene 'Bath Light Night Time' Set 'Master Toilet Light' 0.2 Sec (Ramp Rate) In Scene 'Master Toilet Light' Set 'Master Toilet Light' 100% (On Level) In Scene 'Master Toilet Light' Set 'Master Toilet Light' 0.2 Sec (Ramp Rate)
  8. I have several of the Insteon 2663 (v.44) and use them mainly for LED Christmas lights inside and outside. Once they turn off, they are off with no glare.
  9. KYnewbie replied to KYnewbie's topic in ISY994
    So I guess this is not going to be possible or do I not understand the answer?
  10. KYnewbie replied to KYnewbie's topic in ISY994
    I am so grateful that there are so many knowledgeable and helpful people on this forum. Thanks so much for the help. I have been working on this for several weeks and have not been able to get it to work. The light still goes to 100%. Looks like there are several "Previous message ignored" lines that are probably not good. Thu 02/25/2016 10:56:48 PM : [ Time] 22:56:50 1(0) Thu 02/25/2016 10:56:48 PM : [3C 7A 2 1 ] Link 2 : 0FE8 [A22B3D94BA4C1B01] Saving [..........4C....] Thu 02/25/2016 10:56:48 PM : [3C 7A 2 1 ] Link 2 : 0FE8 [A22B3D94BA4C1B01] Saving [............1B..] Thu 02/25/2016 10:56:48 PM : [All ] Writing 2 bytes to devices Thu 02/25/2016 10:56:48 PM : [3C 7A 2 1 ] Link 2 : 0FE8 [A22B3D94BA4C1B01] Writing [..........4C1B..] Thu 02/25/2016 10:56:48 PM : [iNST-TX-I2CS] 02 62 3C 7A 02 1F 2F 00 00 02 0F EF 08 A2 2B 3D 94 BA 4C 1B 01 09 Thu 02/25/2016 10:56:48 PM : [iNST-ACK ] 02 62 3C.7A.02 1F 2F 00 00 02 0F EF 08 A2 2B 3D 94 BA 4C 1B 01 09 06 (00) Thu 02/25/2016 10:56:49 PM : [iNST-SRX ] 02 50 3C.7A.02 3D.94.BA 2F 2F 00 (00) Thu 02/25/2016 10:56:49 PM : [std-Direct Ack] 3C.7A.02-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Thu 02/25/2016 10:56:49 PM : [All ] Writing 0 bytes to devices Thu 02/25/2016 10:57:04 PM : [iNST-SRX ] 02 50 3C.7A.02 00.00.01 CF 11 00 LTONRR (00) Thu 02/25/2016 10:57:04 PM : [std-Group ] 3C.7A.02-->Group=1, Max Hops=3, Hops Left=3 Thu 02/25/2016 10:57:04 PM : [D2D EVENT ] Event [3C 7A 2 1] [DON] [0] uom=0 prec=-1 Thu 02/25/2016 10:57:04 PM : [ 3C 7A 2 1] DON 0 Thu 02/25/2016 10:57:04 PM : [D2D EVENT ] Event [3C 7A 2 1] [sT] [255] uom=0 prec=-1 Thu 02/25/2016 10:57:04 PM : [ 3C 7A 2 1] ST 255 Thu 02/25/2016 10:57:04 PM : [iNST-SRX ] 02 50 3C.7A.02 3D.94.BA 40 11 01 LTONRR (01) Thu 02/25/2016 10:57:04 PM : [std-Cleanup ] 3C.7A.02-->ISY/PLM Group=1, Max Hops=0, Hops Left=0 Thu 02/25/2016 10:57:04 PM : [iNST-DUP ] Previous message ignored. Thu 02/25/2016 10:57:04 PM : [iNST-SRX ] 02 50 3C.7A.02 11.01.01 CF 06 00 (00) Thu 02/25/2016 10:57:04 PM : [std-Group ] 3C.7A.02-->11.01.01, Max Hops=3, Hops Left=3 Thu 02/25/2016 10:57:04 PM : [iNST-INFO ] Previous message ignored. Thu 02/25/2016 10:57:06 PM : [iNST-SRX ] 02 50 3C.7A.02 00.00.01 CF 13 00 LTOFFRR(00) Thu 02/25/2016 10:57:06 PM : [std-Group ] 3C.7A.02-->Group=1, Max Hops=3, Hops Left=3 Thu 02/25/2016 10:57:06 PM : [D2D EVENT ] Event [3C 7A 2 1] [DOF] [0] uom=0 prec=-1 Thu 02/25/2016 10:57:06 PM : [ 3C 7A 2 1] DOF 0 Thu 02/25/2016 10:57:06 PM : [D2D EVENT ] Event [3C 7A 2 1] [sT] [0] uom=0 prec=-1 Thu 02/25/2016 10:57:07 PM : [ 3C 7A 2 1] ST 0 Thu 02/25/2016 10:57:07 PM : [iNST-SRX ] 02 50 3C.7A.02 3D.94.BA 40 13 01 LTOFFRR(01) Thu 02/25/2016 10:57:07 PM : [std-Cleanup ] 3C.7A.02-->ISY/PLM Group=1, Max Hops=0, Hops Left=0 Thu 02/25/2016 10:57:07 PM : [iNST-DUP ] Previous message ignored. Thu 02/25/2016 10:57:07 PM : [iNST-SRX ] 02 50 3C.7A.02 13.01.01 CF 06 00 (00) Thu 02/25/2016 10:57:07 PM : [std-Group ] 3C.7A.02-->13.01.01, Max Hops=3, Hops Left=3 Thu 02/25/2016 10:57:07 PM : [iNST-INFO ] Previous message ignored.
  11. KYnewbie replied to KYnewbie's topic in ISY994
    I don't think I am following this, are you saying that I need to add this to the scene? I can only add devices and adjust the rates for them. Sorry this is all new to me. I was able to get some lights on at certain times of the day/night to different "on levels" fairly easy. This is the most complex scene/program I have tried.
  12. KYnewbie replied to KYnewbie's topic in ISY994
    I changed the 2477D to a controller (it is red in the scene), changed the names to match below and it still goes to 100% brightness after 10:58pm. Will I ever get the hang of this? Bath Room Light - [iD 0004][Parent 0001] If From 10:58:00PM To Sunrise - 1 hour and 30 minutes (next day) Then In Scene 'Master Toilet Light' Set 'Master Toilet Light' 30% (On Level) In Scene 'Master Toilet Light' Set 'Master Toilet Light' 2.0 Sec (Ramp Rate) Else - No Actions - (To add one, press 'Action')
  13. KYnewbie replied to KYnewbie's topic in ISY994
    I have a scene called "Bath Light Night", inside that scene I have the "Master Toilet Light" (2477D) set as a Responder. In the scene I have the "on level" set to 35%, in the switch I have the "on level, applied locally" set to 100%
  14. KYnewbie replied to KYnewbie's topic in ISY994
    I added the 2477D as a responder, should it be a controller? And why?
  15. KYnewbie posted a topic in ISY994
    Trying to get a simple program to run but I am having all kinds of trouble. Might be because I am fairly new to this. Would like my bathroom light to which is controlled by a 2477D to turn the light on 100% during the day and 30% in the evening. I read and copied a program from the "How To" thread, but it is still not working. I created a scene and put that light switch in it, then did the following program: Bath Room Light - [iD 0004][Parent 0001] If From 10:58:00PM To Sunrise - 1 hour and 30 minutes (next day) Then In Scene 'Bath Light Night' Set 'Master Toilet Light' 30% (On Level) In Scene 'Bath Light Night' Set 'Master Toilet Light' 2.0 Sec (Ramp Rate) Else In Scene 'Bath Light Night' Set 'Master Toilet Light' 100% (On Level) In Scene 'Bath Light Night' Set 'Master Toilet Light' 0.3 Sec (Ramp Rate)
  16. My unit is also version 3.3.10 and I am having the same issue. Could you point me to the manual that you used to get into the Admin Console? Thanks
