bdawson
  1. I guess a little more tinkering is all I needed. I now understand that each KPL button is a controller and that all controllers have their own scene properties associated with them. I was only looking at the main scene definition and now find that modifying the properties associated with the KPL button performs the function properly.
  2. Hello - I just installed and setup my first 5 button KeyPadLinc and have everything working as expected. I then noticed a peculiar configuration issue that I can't figure out how to resolve. It seems that when adding a button on the KPL to control a scene it does not reference the scene from that point forward to determine devices and light levels. This creates a problem when I update the scene with either a new device or change a light setting as the KPL will call the scene with the original configuration that was in place when the KPL was setup to be the controller. Is this the expected behavior when using a KPL and the ISY? ISY-994i v4.3.26 KPL v.45 Thanks! Brian
