jdmcpherson
Everything posted by jdmcpherson
  1. Schlage locks are no better. I was able to connect to my lock a long time ago but no longer. Advice is always the same - get ISY close to the lock. That is a pain but did it. Even at 2 inches fails.
  2. Yes, if you do not have a PLM use the one you indicated. I have a PLM so used the other one.
  3. When I click on the links in the first post shown below, the firmware is downloaded. It doesn't go to a page. 3. Download firmware - ISY 994i Series including Z-Wave support - ISY 994i ZW, Z, or ZS Series (Z-Wave/Zigbee and/or if you do NOT have a PLM)
  4. Check the first post in this thread. Link is there in instructions.
  5. The issue seems to be that I was using the ISY launcher rather than admin16.jnlp (cMP Mac using 10.15.6 - Catalina under open core 0.6.0). I received the error with the launcher (tried 5.1.0 with same error) but with admin16 the updates installed quickly and without incident. I see now that the upgrade instructions say to use admin16 with 10.6.X after the upgrade but the ISY launcher seems to work except for the upgrade. Confused now whether I should always use admin16 on a mac. ISY launcher thread seems to indicate that it works with a mac though.
  6. I'm trying to go from 5.0.16C to 5.2.o RC3. Downloaded the zip file. When I select that to do a manual upgrade I get the the error "Upgrade Failed :Failed uploading file (reported written size is invalid)" I did not unzip the file - it just says select what you download - correct? Suggestions? Thanks
  7. I have tried to install the ambient weather nodeserver. It shows up on PGC and shows and in the admin console after uploading nodeserver config in the web UI. However, PGC shows it as not connected. PGC ambient log shows error below. Additionally, I see no way to add the api key. Successfully built pgc-interface AWSIoTPythonSDK Installing collected packages: AWSIoTPythonSDK, pgc-interface Successfully installed AWSIoTPythonSDK-1.4.7 pgc-interface-1.1.9 WARNING: You are using pip version 19.1.1, however version 19.2.3 is available. You should consider upgrading via the 'pip install --upgrade pip' command. 2019-10-13 17:04:53,182 [MainThread] [INFO ] PGC Interface 1.1.9 Starting... 2019-10-13 17:04:53,306 [MainThread] [ERROR] Traceback (most recent call last): 2019-10-13 17:04:53,307 [MainThread] [ERROR] File "./ambientweather-poly.py", line 9, in <module> 2019-10-13 17:04:53,307 [MainThread] [ERROR] from aiohttp import ClientSession 2019-10-13 17:04:53,307 [MainThread] [ERROR] ModuleNotFoundError 2019-10-13 17:04:53,308 [MainThread] [ERROR] No module named 'aiohttp' As for deleting nodes in admin and PGC, I find that I need to delete it through admin before I can delete it on PGC John
  8. I have proof of concept and see the potential - and like what I see. But, i am having great difficulty in using anything but single word descriptors. For example, "Right Pool Lamp" does not work at all. Was interpreted as "yes"???? Renaming it to "kitchen" and it works fine. Calling it simply pool works fine. It would be helpful to get an updated list of supported device names and whether any pre and post device names will work.
  9. Would like to add waterfall. Although I can't get Alexa to recognize any device at present.
