davidrule
  1. Hi Zellarman What are you using to control your DirecTV receivers? I'm already controlling mine from my ISY via a serial server -> usb serial dongle -> receiver. If you've got a more elegent method I'd love to hear about it. Thanks David
  2. Hi, Please can you send me the name of your friend's company? I've had no end of trouble with CFL bulbs and would like to try some TOPAZ bulbs to see if they help. Thanks David
  3. Right now it is possible to use a program's status as a condition in another program. eg. If Program 'Test Program' is True Then - No Actions - (To add one, press 'Action') Else - No Actions - (To add one, press 'Action') What I'd like to be able to do is trigger when a program's status changes, ie when it becomes true or false. What I have is a program that tracks the status of an X10 device and I'd like to trigger only when that device's status changes. As it stands now, if I trigger on program status, potentially I will retrigger over and over until the status changes again. My work around is simple: trigger on X10 received but I think that linking to a tracked status would be more elegant. -David
  4. Thanks Rand! Your help is really appreciated. -David
  5. Hi Rand, I followed the instructions for clearing the Java Cache and I'm afraid it did not help. My KPL is reported by the ISY as v.29. I don't know if this makes it an older or a newer model. Thanks David
  6. I'm running into difficulty trying to set button toggle modes for my KPL. According to the Wiki, when I click Toggle On/Off on this screen: I should see: But instead I get a dialog box that says "Physically click on Keypad.A, choose your desired state [on/off] and then click on Ok." The dialog box has "OK" and "Cancel" buttons. There are no "Off", "On" or "Cancel" buttons. Firmware is 2.7.4. Thanks David
