Stan in CT
  1. Related, but slightly off topic, I'm unable to find the Alexa app ISY Portal 'Discover' option. It's been a while since I tinkered with this. I've updated some items in the ISY portal but observe in the Alexa app that the Discover option, which used to be at the bottom of the devices list, is not there now - instead it's been replaced. by a couple of options to shop smart plugs or cameras .... ugh. Appreciate any help.
  2. Heartbeat now showing an ON status in ISY Previously I don't recall using the Test button, instead preferring the wet sponge method as a more real-life test. Tried the wet sponge method just now and MobiLinc correctly showed Wet and Heartbeat ON, Dry OFF. Interestingly the sensor did not flash the green LED as a warning. eMail warning received correctly as per program. Double clicked the sensor to reset and the nodes look good. I do prefer the Wet status ON requiring a manual (double click) reset, so I'm good. Thanks all!
  3. Upgraded UI to v4.3.26, thanks LeeG Leak Sensors are all v.43. I've added your program - will wait 25 hours and check. Curious why this is the expected behavior now as I had a different recollection when I first installed these over a year ago - is this an intended change? Thanks Teken for the program link.
  4. Hi, New to this, so appreciate any help from this forum. I have 4 Insteon leak sensors (2852-222) in a near whole house Insteon installation completed over a year ago. A week ago, I noticed a Wet status ‘ON’ on one of the sensors but didn’t receive an alert email that I’d programmed and tested when it was installed. So, I attempted to reset the sensor, but the ISY 994i Admin Console (Firmware 4.3.26 UI 4.1.1) still showed this sensor’s Heartbeat status as BLANK, its Wet was OFF and its Dry was ON. I then factory reset the sensor and linked it afresh and got the same - Heartbeat status as BLANK, its Wet was OFF and its Dry was ON. Note, I did this is close proximity to the PLM, so I know it’s not a location issue, indeed the sensor normally sits with 10” of the PLM. I tested one of the other sensors by simulating a Wet status and as expected the Wet status changed to ON, Dry to OFF and Heartbeat remained ON. An email alert was sent, exactly as I expected. A double click reset the sensor and MobiLinc showed the reset instantly. The rogue sensor doesn’t appear to have any battery issues from what I can see as it cycles through the blinking, fast blinking green LED sequence as is the norm. Any suggestions? Lastly, Is there a way to get an alert when the heartbeat stops? Thanks ​
