gbirk
  1. I have the First Alert SA521CN Interconnected Hardwire Wireless Smoke Alarm and the Insteon Smoke Bridge. I am running ISY 4.4.3. The Smoke Bridge appears in my device list with 7 nodes: CO Clear Low Bat Malfunction Smoke Test Unknown Message The Current State of CO, Clear and Smoke is blank. The others are “Off.” If I run Query on CO, Clear and Smoke nothing the Current State Remains blank. The others will refresh. How do you get CO, Clear and Smoke to show the status? Also what is Unknown Message?
  2. I’ve been considering installing a recalculating hot water system for a while. My plan would be to put a dedicated re-circulating line from the furthest sink back to the hot water heater. A check valve and pump would be installed on the return line. I’ve been considering the Metlund S-70T . Can I just get buy a re-circulating pump like the Taco Model 008 and have the ISY control the pump? I could set rules to have the ISY turn the pump on based on time, motion in the bathroom, a light or fan turned on in the bathroom, etc. With X10, I could connect red and black wires from the Metlund to terminals on a Universal Module (PUM01), set the selector switches to “Momentary†and “relay onlyâ€, and plug it into an outlet. Can the ISY communicate with a PUM01? If not, does Insteon have a similar module? I'm wondering what kind of ideas you guys might have as far how to automate the system. Thanks in adavance.
