zimtekcom
  1. 2441TH - Ghost Button Input / Ghost Mode Change (Random Mode Change, Random Button input - related to Dirty 24vAC power supply) associated with Igniter related interference broadcast to the Thermostat through the thermostat wiring. Thanks all for the good info on use of a surge suppressor, what amazes me is how horribly designed this device is.. And with that.. For Trouble Shooting: Turn on the "Beep on button press" (#6 Below) - you will now be able to hear your thermostat "Ghost" input as it happens. The workaround: And if you can live with only using the phone (or windows) app to set the temperature and Mode... there is a simple work around. The workaround is to disable the button input. Turn on the "Button Lock" (#7 Below). Ridiculous I know - Unfortunately this is the limited way I've had to run this Thermostat (and it's RMA replacement) for the almost 2 years I've had these very disappointing Insteon products. http://cache.insteon.com/documentation/2441TH-en.pdf User Setup Mode 1) Press and hold Program button to access the following options: • Press Mode to step between menu items (sub-mode number will appear on top of the screen). o Sub-mode 01: Display LED on-time select (default is 10 seconds) o Sub-mode 02: Humidity low setpoint (default is 30%) Page 20 of 28 Rev: 4/21/2015 10:16 AM o Sub-mode 03: Humidity high setpoint (default is 90%) o Sub-mode 04: Temperature format select (default is Fahrenheit) o Sub-mode 05: Beep on button press (default is Off) o Sub-mode 06: Status LED (default is Off) o Sub-mode 07: Button lock (default is Off) o Sub-mode 08: Programming lock (default is Off) o Sub-mode 09: Activation delay (default is 5 minutes) Good luck everyone..!! --Bill Zimmerman-- 2441TH-en.pdf
