interactii
  1. I have a number of programs setup in my ISY that act on Fast On or Fast Off of various switches, or take action when something is switched off. These all worked fine for years, but after a recent series of power outages, none of them work at all. Other programs, including ones triggered by sunset and sunrise, and ones initiated by Amazon Echo work just fine. I've tried power cycling the ISY and the 2413S and the but it doesn't change. When I look in the Event Viewer with level set to 3, I can't see any traffic other than that generated by the ISY - like if I turn on a light with a switch nothing shows there, but I don't remember if it i ever did. Anyone have any suggestions as to what steps I can take to try to resolve this?
  2. It started working in steps last night, at 7:30 they could see each other but the portal was waiting for authorization but the ISY showed no request. Then by 9 PM, I was able to re-approve the device in ISY and it's now working again, and it is definitely more responsive.
  3. My problem is that the ISY portal can't even talk to my ISY. The problem comes in before it even gets to the echo level. I've tried calling support but no one picks up
  4. I can't the the portal to connect to my device or vice versa since the downtime last night. The ISY994 reports "offline" and the portal the same. I've tried rebooting the ISY, checking all it's network settings again, I've also tried removing it from isy.io and readding it, no difference. What else can I try to get it running again?
  5. Hi there, it doesn't seem that at the moment dimming scenes is supported with Echo ("That command doesn't work on device x"). Does anyone have a way around this? I use scene dimming in all kinds of ways (each room of mine has 5-7 individual devices) and not having this is a real bummer. Thanks!
