Schwell
  1. I set them up to turn on/off individually and it seems to be working. Thanks for the help! Sent from my iPhone using Tapatalk
  2. I set them up to turn on/off individually and it seems to be working. Thanks for the help! Sent from my iPhone using Tapatalk
  3. I have a set of 3 insteon on/off switches setup in a scene to control my outside lights. I have a program that runs every night and morning to turn these lights on and off. I have noticed that a few times, my front light is still on in the morning. In the ISY, it shows as off, but the light is on and the switch indicates that it is on. It seems to be random on when it works and when it doesn't. I also looked at the main log and that shows it going to off this morning. It seems to just be getting the incorrect status on the one front light switch.
  4. Thanks for all of the input. Just ordered an in-linelinc dimmer. Sounds like that will do the trick!
  5. Hello, I am going to be installing can lights and would like to get them installed with no switches physically wired into them. I have 2 KPLs with open buttons that I would like to use to control them. Would it work if I just used a micro dimmer switch in the ceiling box and capped off the sense wires? Or is there a better way to do this? Micro Dimmer Module: http://www.smarthome.com/insteon-2442-222-micro-dimmer-module.html
