thehose
Everything posted by thehose
  1. Thanks Brian, I'll just get the caps then. It may be while but I will let you know if the fix worked...
  2. Brian, Jumon Thanks for the clarification, I now have my shopping list together. I may try a fix without replacing the C2D on the daughter board (availability), maybe it will work as it did for jumon. I have a last question regarding the Pi filter, the third component in the filter is the inductor labeled 1Mh (the only marking on the piece). Should I replace that and if so what is it ??
  3. Brian, No confusion from you. I could not get the exact parts locally so I tried the mouser.com site and there still can't get the exact part numbers either. So I picked some as close as I could get to what I think I need but would feel much better if you could give them a look over before I order and try the re-cap. Thanks Original Part New Part# Current Mouser.com part# C3 Replace YICCON 6.8uF 250V cap with ESX106M400AH4AA 10uF 400 volt ESX106M400AH4AA 10µf 400v C11 Replace FUJICON 100uF 25V cap with UTT1E101MPD 100uF 25 volt UTT1E101MPD 100µf 25v C7,13 Replace SAMCON 10uF 35v cap with EKY-500ETD101MHB5D 100uF 50V (2 of these) ***HLH EKZM500ETD101MHB5D 100µf 50v << different PN C8 Replace FUJICON 10uF 16V cap with UTS1C100MDD 10uF 16 volt UST1C100MDD1TE 10µf 16v << different PN C2D Daughter board 100uF 6.8V EKY-100ETD101ME11D 100uF 10V ***HLH EKMG100ETD101ME11D 100µf 10v << different PN
  4. Thanks Brian, looked up π filters and educated my self a bit. I will re-cap this PLM and post back my results....Thanks for the help !
  5. Well, so this is what I found and I could use help with what I labeled C7 & C13. I don't have a C13 marked on my board, just have that mess and a lead going to pin C21 on the underside of the board. Any help in that area would be appreciated.
  6. Yes, this definitely was a fixer-upper and the back of the board is a mess. I'll clean the board with alcohol and will identify component values. Need my magnifying glass for that. I'll post a picture with what I actually have. Thanks for the fast reply..... I will give this a shot, not much to loose since I can get the components locally.
  7. Hey folks, just found this topic while Googling for PLM not working. I'm glad is in this forum, because I just bought an ISY-994izw that I'm trying to setup. I ordered a new 2413s from Amazon but decided to try to fix this one as a spare as these thing don't seem to last long. Having said that, I bought mine in 2011 so about six + years of daily use. Anyway, I opened this puppy today and here's some pics of what this looks like, specially the caps in the middle of the board. Has anyone successfully re-caped one of these little gems ?
