TimCA
  1. I will run out today and pick up a new micro SD card... Fingers crossed, and I let you know. Again thank you so much for helping through this process..... Tim
  2. Ok so I removed the SD card and cleaned it with an eraser. Reinstalled it and plugged it back in. The OSY 994i is still blinking the same....
  3. So short of the full resetting, first I am running through the Error light and Memory light blinking simultaneously, list, The lights on the Network jack have one steady on and the other one blinking. If not, check cable and connectivity to the router No lights, swapped out cables and tried other working ports on the router. no Change. There are no lights on the back network port of the isy. I swapped out the cables and still nothing. The router that sits next to it is working fine for both wifi and c5 homerun cables to other computers, just not the isy. Also worth noting, the PLM does not have any LEDs let up. I don't know if that is normal or not its been working flawlessly for years without looking at it. Thoughts? Tim
  4. OK, so I have a 12v / 2.0A power supply from another small electronic devise. I swapped it out.... same thing, boots up then red light flashing every second, and of line message. 😒
  5. Copy, Ill try that... are they generic or specific power amount?
  6. Good morning, I have been using my ISY for several years with no issues. I am a beginner in the home automation, IE I somehow got it to do what I wanted and stopped tinkering in home automation. I have no coding or true computer skills. I use a PC and android. My switches are all Instron and my subscription is current. Firmware is 5.3.0 With all that said, we had the power go out last Sunday during a thunderstorm. After the storm passed and the power came back on everything in the house seemed fine (Alexa working, computers fine etc..) I noticed that my outdoor lights were coming on at odd times, then noticed that my lighting voice commands to Alexa were not working. I opened the ISY portal and it states "Offline since Sunday...." So I do the normal beginner stuff, unplug , wait and re plug in the units a few times then search the internet. No change Looking for so guidance and assistance getting back to "normal". Thanks Tim
  7. I guess that is the problem I cant even find the "Figure 7 Menu". Here is what I have via my computer and online
  8. Good afternoon, It has been awhile sense I have added a device and after a web search and pulling my hair out I am back here. I added an outlet. I have an ISY I have a 6 link switch. I can get to my ISY portal. Here is what I want to do. I want to be able to switch the outlet on and off from the "D" of my 6 link. "A" and "b" already switch other scenes. For the life of me I can not find any way to "Add a device" ISY portal ---Tools -- ISY web access- than what???? AND how??? Thanks Tim
  9. Bummer, thanks
  10. Good morning, I have a Insteon 2472DWH that I have lost the key to. I want to just switch a load on and off do I need a "dimmer key' or as the name implies is that only needed is I want to dim the lamp. Thanks Tim
  11. Well look at me all grown up.... I got it to 5.3.0 !!! now I can try the mobile app thing again... wish me luck. Tim
  12. A bit more info, When I go to the link provided above, https://forum.universal-devices.com/forum/15-current-release-betas-and-bug-reports/ I see there ate to I should down load the newest version and the several below the launcher. when I click on the launcher, shipping the clear Java step because I don't have Java on my computer, I get this, https://isy.universal-devices.com/start.jnlp This type of file may harm your computer." Tim
  13. Ok, well let me ask you this, Given at age of my version and the fact that I only run 3 keypads + 5 switches and one outlet. All together I have 4 preset scenes (one on time every day and 2 voice controlled via echo) all insteon for now. I plan to add to the system in the next 4 months so several current presets will change. (more insteon, a weather station, and possibly irrigation. Would it be easer to just start from scratch? Is there a way to just erase the current version and start clean with newest version. Also, I tried to down load the launcher with no luck, first it had me clear the Java cash.... I don't have Java on here. Then it gave me an error message after a warning that the program could damage my computer.... Any thoughts on either , Thanks Tim Model: ISY 994i 1024 IR Platform: ISY-C-994 Version: 4.5.1 Build Timestamp: 2016-06-15-14:06:00
  14. Thanks for the info. So here is what I have. Model: ISY 994i 1024 IR Platform: ISY-C-994 Version: 4.5.1 Build Timestamp: 2016-06-15-14:06:00 I "normally" do not access my ISY except when I get a wild hair to add something of change somethin which apparently is about every 2 years. In witch case I need to relearn how to do it. This is the first time I have run into this updating issue. So it sounds like basically if I want to use the UD mobile app I need to update to 5, and that will not be a walk in the park but is doable. If I want to add a mobile app to control my current ISY I can try the GO2ISY app. Any benefits other than the mobile app to updating the firm where? I will first work on the launcher upgrade as I have always gone to ISY portal then My ISY from there. I am assuming nether of those are the Launcher. lilyoyo- thanks for the response I will keep looking for another option. Outdoor outlet.
  15. Good evening, I am trying to control an outdoor switch (Smart WiFi Indoor/Outdoor Plug MSS620HK / MSS620 US) witch led me to try to down load the UD app on my phone. I then learned that I need to update my firm where, but before I do that my "Admin Panel". Why this is not done automatically is odd to me but, I have no idea where to start I read the thread about updating, and it seemed that i need a degree in IT to get through this, it also states that I need to update my admin panel.... what and where is my admin panel? I only dabble in home automation and the last time I set it all up was about 18 to 24. Hoping I can get a little guidance. Thanks for your help Tim
