apodsim
  1. The settings referenced above is what I have set in the Two programs I pasted to the orginal post. When I select the Before or After setting prefix the setting change which negates the period schedule. I assume that not having a H:M:S time period set should make any not difference as Sunset and Sunrise continue to change thoughout the year. The program "Carriage Motion" which is set to Sunrise and Sunset the same day keeps any motion from turing on the lights. When I enable the Carriage 35% program "Carriage Motion" in the IF statement provides a TRUE and set the lights to full ON else set to %35 if FALSE. This is overriding the other program "Carriage Motion" because the FROM and TO are both set to AFTER Sunrise and Sunset NEXT DAY. If the To schedule are not set to "Before" any motion will turn the lights ON regardless of the time of day. IMO the scripting is the problem due to the reasons expained in the message thread.
  2. This is for UI Ver. 4.9.0 ISY 994i(1120) I am trying to create a script that interacts with my Motion Sensors to change the outdoor lighting level depending on motion and OFF during daylight hours. When selecting Schedule If statement From Sunrise After and To Sunset Before settings changes back to After on Update. When selecting Save Changes the box in RED below returns to After from the Before setting. The second program "Carriage 35%" keeps the motion detection active during the daylight hours. The program "Carrige Motion" is OFF between Sunrise and Sunset the same day. This program forces the lights to respond to motion between After Sunset and Before Sunrise the next day. Alternative suggestion are welcome.
  3. apodsim replied to apodsim's topic in ISY994
    I submitted a Trouble Ticket to UDI support and was able to resolve the issue with a remote in from support. The problem was apparently caused by a program on my computer that changed the .jnlp extension association. Another action support did was to open the JRE Control Panel along with clearing the cache, the check box "Installed Applications and Applets" was selected. Before this was done the Java Cache Viewer did not list the ISY Launcher as shown below.
  4. apodsim replied to apodsim's topic in ISY994
    I did follow the instructions from @Geddy which I found as a possible soultion from other users having this problem before creating this post. When I run the dowloaded start.jnlp another program dialog box appears that apparently uses JAVA programming lanuage. I attempted to associate *.jnlp however, it is technically not a program in windows as such I was not able to change the file association.
  5. apodsim replied to apodsim's topic in ISY994
    I am running Windows 10 using JAVA JRE 32 bit Version 8 Update 321 downloaded from Official JAV website which was was working with the Admin colsole previously. My ISY backup shows version 4.9. Both admin and startup .jnlp links downloaded form the UD WiKi produce the same error launching from a pinned Administrative Console in the startup menu.
  6. apodsim posted a topic in ISY994
    After many years of not having any problems, yesterday I launched the ISY admin module and was greated with message "illegal URL redirect". I have tried emptying all of my cookies, browsing history and unistalling JAVA JRE the same error message shows. I am running out of options. Anyone elese having this problem that can help resolve this problem? Thanks in advance.?
