Sergey
  1. OK. got it to work. 1. Read the doc carefully. it does say how to get into advanced settings. though it warns you "do not do it", you have to. 2. noticed in the thread the url youisy/rest/zb. after checking that isSEP="true" is there kinder forgot about it but refreshing it having no other ideas noticed that data appears there. correlated it to the other info and noticed my meter entry in there including Extended PAN ID. 3. when you are in the advanced configuration either use binoculars (be patient) or enter PAN ID by hand. and it worked!
  2. Hello, This topic seem to be quite old but I will try. I just got and installed High Powered Zigbee Smart Grid (SEP1.1) Radio module for my ISY994i. Followed all the instructions from UDI and PG&E. Did not succeed so far. Devices (meter and ISY) are unable to connect. The ISY keeps scanning periodically.Talked to PG&E's support. They said that everything looks good on their side. PG&E also mentioned that some reset of my device is required and they used to do it but now they say that UDI wants to do it themselves. Can I get some info on that? The documentation mentions a soft reset ut a password id needed. The doc says the password is the same as for Advanced Configuration but I do not know where to get that password. One more thing. There is an LED on the module. What is its function? Thank you for help, Sergey
