Katrinia
  1. The brackets in the program fixed the flashing!! Thank you!
  2. Only with the motion sensors.
  3. Hi, I have a 3 very simple programs set up.(Below) There are two lights, on the same switch. When the lights turn on, they flash three times. I had the electrician come out and look and he switched around the bulbs (florescent vs. old school) and it changed the flashing order. I have a similar problem in my mud room and pantry. I am at a loss. Any ideas? Downstairs Hall-Dance-Day - [iD 0045][Parent 0051] If Control 'Devices / Motion Sensors / MS DHall LR' is switched On Or Control 'Devices / Motion Sensors / MS DHall Stairs' is switched On And From 7:30:05AM To 5:59:00PM (same day) Then Set Scene 'Scenes / Inside Lights / Downstairs Hall 3 way' On Wait 3 minutes Set Scene 'Scenes / Inside Lights / Downstairs Hall 3 way' Off Else - No Actions - (To add one, press 'Action') === If Control 'Devices / Motion Sensors / MS DHall LR' is switched On Or Control 'Devices / Motion Sensors / MS DHall Stairs' is switched On And From 10:30:00PM To 7:30:00AM (next day) Then Set 'Devices / Downstairs Hall / Downstairs Hall: LOAD' 40% Wait 3 minutes Set Scene 'Scenes / Inside Lights / Downstairs Hall 3 way' Off Else - No Actions - (To add one, press 'Action') === Downstairs Hall-Dance-Evening - [iD 0044][Parent 0051] If Control 'Devices / Motion Sensors / MS DHall LR' is switched On Or Control 'Devices / Motion Sensors / MS DHall Stairs' is switched On And From 6:00:00PM To 10:29:00PM (same day) Then Set Scene 'Scenes / Inside Lights / Downstairs Hall 3 way' On Wait 3 minutes Set Scene 'Scenes / Inside Lights / Downstairs Hall 3 way' Off Else - No Actions - (To add one, press 'Action')
