badvector
  1. I should have checked this thread before I started configuring my second dot. I just followed the wiki. Just to confirm, if it doesn't matter if they use the same commands I can simply add it to my primary amazon account and no sub accounts in the portal are required? Where as, if I want independent control of two different areas, I would configure it using multiple amazon accounts and portal sub-accounts as outlined in the wiki? Thanks in advance. I've just started using the ISY instead of the insteon hub and my head is still spinning with the abilities available with the ISY.
