teksavy
  1. I'm wondering what version you upgraded to v6.0.5 from? Was it v6.0.4? I upgraded from v6.0.0 to v6.0.5, so I wonder is that had something to do with it? I have a small zigbee network- only 3 devices, Qty 2 Third Reality ZB motion sensors and an Innoveli Ceiling fan controller. -Ed
  2. TL;DR- If you are using the UD ZMatter ZWAVE/Zigbee dongle and are using Zigbee devices... DO NOT UPGRADE TO v6.0.5! (Rolling back to v6.0.4 restored zigbee ability) I've been a Universal Devices user for over 10 years and have been happy with the performance and upgrades I've experienced so far... at least until last week when I upgraded from EISY v6.0.0 to v6.0.5. When I upgraded to v6.0.5, my zigbee devices stopped working. I couldn't query or add ANY zigbee device back to my system that actually worked. I tried factory resetting the zigbee side of the UD ZMatter Zwave/Zigbee dongle and that didn't help either. When attempting to add a Zigbee device, it would be discovered as a generic device that wouldn't update status or control anything. (See screenshot attached). I opened up a ticket with UD and much to my surprise, Michel responded on a Sunday! Kudos to the support team! They asked for the Zigbee log which I sent them, they replied that my previously working zigbee devices were using "old security keys or credentials" but that clearly wasn't the case. Current status is that Michel is working with the developer and will update at some point. Until then, I'll stay happy with v6.0.4. I'll update if I get new information. -Ed
  3. THANK YOU @Bumbershoot! Somehow I missed that post in my searching. It solved my understanding problem! -Ed
  4. So I bought a ZooZ Zen32 800LR basic dimmer switch and tried again. Luckily this time I have commands now. (see below) but the switch still doesn't turn off/on the lamp dimmer. Still seems like the direct linking isn't working with EISY. Is this even possible? Here is my scene:
  5. Yes, the only thing I got was "query". Not helpful in the least. -Ed
  6. Hi: I have a new EISY (from a ISY994i) and I'm starting the transition from Insteon to ZWAVE. I have having a hell of a time creating native (direct) links between two devices using my new EISY with ZMATTER USB interface. (Note that I didn't have any ZWAVE devices on my ISY994i when I moved my config over to my new EISY- starting fresh with ZWAVE on the EISY.) Can someone please tell me what I am missing? I'm simply trying to link a ZooZ Zen32 to a simple plug in lamp dimmer (New One N4012) using a native (direct) link with my EISY. For the life of me I can't see to get the drop down options to actually do what I want. I only have Command, Default and Ignore options. It seems based on research that I should have other commands like on/off there to actually do something. I have tried direct links with the scene buttons, Basic Assoc and the switch itself.... all with no avail. What am I missing? Note, I know I can do the "3 button click" on each device to direct link them, but I don't want to do that since I've been spoiled with Insteon. I'm running IoX v5.7.1. Any ideas are super appreciated... I'm been banging my head on this for a while.
  7. Here is the new program with tweaks made to it to actually work... Posting here in case someone else runs into the same understanding problem I did... If From 12:59:00PM on 2017/05/01 To 7:01:00PM on 2017/10/31 And On Mon, Tue, Wed, Thu, Fri From 1:00:00PM To 7:00:00PM (same day) And Status 'Devices / HALL / HALL-Therm- Main' is Mode Cool And Status 'Devices / HALL / HALL-Therm- Main' <= 77° (Cool Setpoint) Then Set 'Devices / HALL / HALL-Therm- Main' Mode Cool Wait 2 seconds Set 'Devices / HALL / HALL-Therm- Main' 78° (Cool Setpoint) Else - No Actions - (To add one, press 'Action') Couple of notes for newbies like myself: If you place the weekday (Mon, Tues, Wed...) on the first date line (12:59:00PM on 2017/05/01), it will not work correctly (ask me how I know). The weekday specification must be on the daily time portion of the if statement (from 1:00:00pm, etc). Thank you everyone for the help! -Ed
  8. Ahhh! THANK YOU! I incorrectly made the assumption that the time applied to the daily schedule rather than on that start date and end date. It 5.0.10 still in beta?
  9. Just wrote a new thermostat program to help reduce energy costs during peak times. If On Mon, Tue, Wed, Thu, Fri From 1:00:00PM on 2017/05/01 To 7:00:00PM on 2017/10/31 And Status 'Devices / HALL / HALL-Therm- Main' is Mode Cool And Status 'Devices / HALL / HALL-Therm- Main' <= 77° (Cool Setpoint) Then Set 'Devices / HALL / HALL-Therm- Main' Mode Cool Wait 2 seconds Set 'Devices / HALL / HALL-Therm- Main' 78° (Cool Setpoint) Stop program 'Sched-ThermSetPeakRate' Else - No Actions - (To add one, press 'Action') Program does what I want EXCEPT that the time condition doesn't seem to get evaluated. If I try lowering the thermostat to 72 after 9pm, it keeps setting the thermostat to 78... Yes I checked the on board clock.. it is correct. What am I doing wrong? Help please -Ed
