heyphets
  1. Thanks Michel! I believe even if you had wildcard certificate installed (the current one installed doesn't appear to be a wildcard), it would only help to cover all subdomains (e.g. <anything>.isy.io), but not the main domain itself. You should be able to add the isy.io as a subject alternative name though, then I believe it would work fine without a redirect.
  2. Hi All, My first post on the forum, thanks to community for everything you do to move the home automation forward. I've noticed that the ISY portal is available both at https://isy.ioas well as https://my.isy.io, however the SSL certificate is only issued to my.isy.io. May I suggest an HTTP 302 redirect to be added to isy.io to my.iso.io to avoid browsers freaking out because of the hostname mismatch between URL and Certificate?
