jeremybe
  1. Thank you all - Problem solved! I guess I was trying to over engineer here!
  2. The Electrical box is in the ceiling behind one of the highats - HIdden away - Can I just throw a switchlinc in the ceiling and just use that? It wouldn't be seen at all - The KPL is the only control With Regards to the fanlinc, the lights I'm currently controlling are incandescent 45w high hats - They are dimmable although I really only use on/off - So I don't see why the fanlinc wouldn't work and looks like its smaller/easier to hide.. ?? Wouldn't the fanlic support Instant On/Off? Thanks!
  3. Looking for some advice - I have a house full of Insteon and have owned an ISY since day 1 - Everything works and I haven't had to touch it - One of my Switchlink In-Line Relays (Insteon 2475DA1) that control 6 45 watt high hats just went on me - This switchlink is usually triggered by a press on an Insteon Keypadlinc button- It Looks like these in-line relays are no longer being made and none are on EBAY- Hard wiring would be a real pain - My ISY has the ZWAVE module - Is there a ZWAVE module I could use as a replacement for this? Another thought I had was utilizing the Insteon Ceiling Fan and Light Control Module, sticking it in the box and not hooking up the fan wire -The load should be fine.. Looking for any options/thoughts Appreciate the help...
  4. I had a faulty Switchlink dimmer, replaced it with a new one and ran the "replace with" command in the iSY console - The Switchlink is part of a scene - When attempting to control via the Echo"Kitchen Lights On" all lights except for the new switchlink turn on - Also, in the console the new device has a "1011" next to it. Any ideas how to get this working?? Thanks!
