yaplej
  1. Any chance you plan on adding camera support? The ability to add a camera, enter the URL, username, password then when clicked would show the stream? Showing a thumbnail image from all the cameras would be extra cake. I have been waiting for an App that can integrate ISY + Elk + Cameras for my wife. I could get it done with three different apps but would rather everything be integrated into one.
  2. Hello, So I created a program that is triggered "if Device is not responding" how long does it take before that will actually trigger normally? Is that what the default "Query All" is for? In order to speed that process up I created a Program than run every 15 minuets and in turn runs these type of Programs. Is there a better way to have it periodically check the status of the devices?
  3. I thought using a program instead of linking the relay directly to Alexa would work but Alexa just doesnt understand "close <this thingy>".
  4. I just got the ISY Portal setup and Alexa is now able to control some of my devices. However Alexa is not able to correctly close the garage door. I can say "open the garage door" and that works but "close the garage door" does not. If I say "open the garage door" again it will actually close the door. My guess is because the relay is open On for about 2 seconds and then is turned off again because it is acting like the push button. So "close" to Alexa is the Off state and the relay is already in that state so it does nothing.
  5. It probably wouldnt be a problem except stacking the FilterLinc on and I/O Linc would result in one huge conglomeration dangling from the ceiling outlet. Would probably need to do something to secure it up there to make sure it doesnt fall. However I just got a few LED bulbs on my trip to Lowes and everything is working fine now. No more CFL's and the garage door motor doesnt seem to cause the same problems that the CFL's were. Even my florecent bulbs in the garage are not causing any problems so far. If they do I would probably install something like the Leviton inline filters before the balast.
  6. So I have a ton of CFL lights all over and I just discovered how much problems they can cause you with Insteon signals. I put one of my I/O Linc units on the garage door outlet on the ceiling of my garage. The garage door openen has two lights in it (both CFL). Anytime I would trigger the garage door opener with the relay on the I/O Linc I would lose connection to the I/O Linc for a while. Turns out that the lights on the garage door opener were coming on and they happen to be CFLs. It was causing so much interference that it would cause the I/O Linc to fail communicating with the PLM. Im pretty sure its the CFL and not the motor (but it could be both). When I manually turned the CFL lights off I could then Query the I/O Linc again. So should I put a filter on the garage door opener? I would really like to get something less bulky that the Insteon filter. Perhaps something I can install in the garage door opener maybe.
  7. Yeah after playing around with it thats what I determined also. Now the logic seems pretty limited I could not figure out how to do it all withing two programs. I wanted to have one program for "Up" and another for "Down" but with the current logic it seems like you cannot do ifelse or switch statements inside of the if/else/then enviroment. So I ended up with several programs to cycle through all the "Up" states and another several to cycle back through the "Down" states. They are all triggered by the "Control" button being set to On on my keypad and its set in non-toggle mode so each button press triggers the action based on the current state. Kind of a mess but its doing the job. The dimming light isnt really doing much because the CFL lights that came with my new fan are not dimmable. Ill have to get some dimmable LED lights and see if that helps. Thanks.
  8. I have a FanLinc and a Mini Remote 8 button keypad. Is it possible to use one button to cycle between off->25%->50%->75%->100%? The only place that seems to work would be inside a program. A scene on the remote button seems like it can only set devices to a specific state instead of cycle through them like a dimmer.
  9. I have the PLM in my office right now. Lots of computers, printer, UPS and power strips. Hmm. I'll look into getting a filter for the UPS and printer for starters.
  10. I got a really long network cable and put the PLM in a different outlet/circuit/room. It worked! So I put it back into the oringial room in a different outlet. Still on the same circuit and its still working. Was even able to add my FanLinc that I installed upstairs (pretty sure its not connecting wirelessly). Now I am going to try and write a program to monitor the I/O Linc with the feezer sensor on it. Should be fun!
  11. This is my first setup These devices are the first I have connected and tried to Link. I/O Linc 2450 (with Minotaur Engineering IVT2) I/O Linc 2450 (Garage Kit) I also have some other devices ready to add: FanLinc 2475F Dimmer Switch 2477D Keypad Dimmer Switch 2334-2 Mini Remote 2342-2
  12. I unplugged both the PLM and the ISY getting everything into one outlet. So everything has been power cycled multiple times at this point. However I did it again and same behavior with both devices. Fri 06/24/2016 03:40:36 PM : Start Insteon Device Linking Mode Fri 06/24/2016 03:40:36 PM : [LNK-BGN ] 02 64 01 00 06 Fri 06/24/2016 03:40:46 PM : Stop Insteon Device Linking Mode, Final processing to follow Fri 06/24/2016 03:40:46 PM : [LNK-END ] 02 65 06 : : Unexpected, ignored (65) Fri 06/24/2016 03:40:46 PM : [All ] Writing 0 bytes to devices Fri 06/24/2016 03:40:46 PM : [All ] Writing 0 bytes to devices Fri 06/24/2016 03:41:57 PM : [3D E3 2B ] Added to list of devices to link to ISY Fri 06/24/2016 03:41:57 PM : [INST-TX-I1 ] 02 62 3D E3 2B 0F 0D 00 Fri 06/24/2016 03:41:57 PM : [INST-ACK ] 02 62 3D.E3.2B 0F 0D 00 06 (00) Fri 06/24/2016 03:42:06 PM : [INST-TX-I1 ] 02 62 3D E3 2B 0F 0D 00 Fri 06/24/2016 03:42:06 PM : [INST-ACK ] 02 62 3D.E3.2B 0F 0D 00 06 (00) Fri 06/24/2016 03:42:15 PM : [INST-TX-I1 ] 02 62 3D E3 2B 0F 0D 00 Fri 06/24/2016 03:42:15 PM : [INST-ACK ] 02 62 3D.E3.2B 0F 0D 00 06 (00) Fri 06/24/2016 03:42:19 PM : [3D E3 2B 0 ] Failed to add device, reason 3 Fri 06/24/2016 03:42:19 PM : [All ] Writing 0 bytes to devices Fri 06/24/2016 03:42:42 PM : [3D 4D CB ] Added to list of devices to link to ISY Fri 06/24/2016 03:42:42 PM : [INST-TX-I1 ] 02 62 3D 4D CB 0F 0D 00 Fri 06/24/2016 03:42:42 PM : [INST-ACK ] 02 62 3D.4D.CB 0F 0D 00 06 (00) Fri 06/24/2016 03:42:50 PM : [INST-TX-I1 ] 02 62 3D 4D CB 0F 0D 00 Fri 06/24/2016 03:42:51 PM : [INST-ACK ] 02 62 3D.4D.CB 0F 0D 00 06 (00) Fri 06/24/2016 03:42:59 PM : [INST-TX-I1 ] 02 62 3D 4D CB 0F 0D 00 Fri 06/24/2016 03:42:59 PM : [INST-ACK ] 02 62 3D.4D.CB 0F 0D 00 06 (00) Fri 06/24/2016 03:43:03 PM : [3D 4D CB 0 ] Failed to add device, reason 3 Fri 06/24/2016 03:43:04 PM : [All ] Writing 0 bytes to devices
  13. I/O Linc and PLM in the same outlet... Still wont link/detect the I/O Linc. Here are the logs from both. Both I/O Linc addresses start with 3D. No device in the list start with that address range so I thought maybe it was a new revision of the 2450 that might need to be added. Fri 06/24/2016 03:30:08 PM : Start Insteon Device Linking Mode Fri 06/24/2016 03:30:08 PM : [LNK-BGN ] 02 64 01 00 06 Fri 06/24/2016 03:30:27 PM : Stop Insteon Device Linking Mode, Final processing to follow Fri 06/24/2016 03:30:27 PM : [LNK-END ] 02 65 06 : : Unexpected, ignored (65) Fri 06/24/2016 03:30:27 PM : [All ] Writing 0 bytes to devices Fri 06/24/2016 03:30:27 PM : [All ] Writing 0 bytes to devices Fri 06/24/2016 03:32:30 PM : [3D E3 2B ] Added to list of devices to link to ISY Fri 06/24/2016 03:32:30 PM : [INST-TX-I1 ] 02 62 3D E3 2B 0F 0D 00 Fri 06/24/2016 03:32:30 PM : [INST-ACK ] 02 62 3D.E3.2B 0F 0D 00 06 (00) Fri 06/24/2016 03:32:38 PM : [INST-TX-I1 ] 02 62 3D E3 2B 0F 0D 00 Fri 06/24/2016 03:32:39 PM : [INST-ACK ] 02 62 3D.E3.2B 0F 0D 00 06 (00) Fri 06/24/2016 03:32:47 PM : [INST-TX-I1 ] 02 62 3D E3 2B 0F 0D 00 Fri 06/24/2016 03:32:47 PM : [INST-ACK ] 02 62 3D.E3.2B 0F 0D 00 06 (00) Fri 06/24/2016 03:32:51 PM : [3D E3 2B 0 ] Failed to add device, reason 3 Fri 06/24/2016 03:32:52 PM : [All ] Writing 0 bytes to devices
  14. I have a 994 Firmware and UI are 4.4.6. I have not. However I also just got a new garage door kit from Smarthome and it included another I/O Linc 2450 with a similar address. I plugged that device into an outlet near the PLM and its doing the exact same thing. Perhaps ISY does not recognize I/O Linc 2450 version 2.4?
  15. It does not have an "®" in the product number. When I ordered it it didnt say refurbished but that was the only option for the IO Linc 2450 outside of the "Auto Detect" option.
