KEoqgtkQ
  1. I have 7 countdown timer switches (2476ST) that come on and stay on after a power outage. This is very annoying. I don't know if it's a firmware bug or what. a) Has anyone heard of this or have any suggestions how to fix it? Is there some way for me to run a program on the ISY after it is rebooted? This way, hopefully I can run a program after the power outage to try to turn the switches off. Thanks.
  2. From what I can tell the applied properties come from the Controller that is used for the scene. What's the point of the properties of a device that is a Responder in a Scene?
  3. Ok, I've done as you said and I suppose it worked. However, I've meticulously gone through the PLM links table and it has a few links to devices that are no longer on my network. Now what?
  4. It's not. I don't understand why I would need to do that. If the ISY's link table matches up to the device, then why doesn't it represent those links in the GUI?
  5. I have a switch that comes ON unexpectedly. I tracked it down to a link to another switch that has been relocated. When I go into the GUI and get the Device Links table for the switch that comes on, it shows links to 2 devices I don't want it to be linked to. Using the "Compare" function shows that the links all match up to the ISY. I also used the "Restore Device" command on the switch and nothing changed. So, how can I remove the links for these 2 other devices? One device is no longer on the network, and the other one is. Also, for the device that is still on the network, there is NO scene in the ISY that shows it linked. Thanks.
  6. Ok, thanks.
  7. That looks good, but is there any way to automatically do it for the entire network? It will take me hours to do all my devices individually. Thanks
  8. Is there any way to have the ISY detect devices that have stale or unknown links? E.g. I had a switch that I removed without unlinking it. A switch that is known to the insteon still shows links to the removed device if I manually view the device links, but there is no obvious indication that the linked to device is a phatom.
