taskman
  1. Hi, As I mentioned to Michel Kohanim yesterday, your console needs a link to display those devices that are active, especially in the iPhone and devices similar but on the main system as well. We are talking about a simple query to display only those devices, only those scenes, only those devices then under that those scenes or you could have it as an option to display active items at the top then the rest of them. However you want to do it. can pick one and have 1 active items link or have more than 1 link to display the selected query as mentioned above. But as a minimum I would suggest a link to display active devices. Thanks PS. I suggest the display is in edit mode as it is now so they can be changed and not just a display of the facts
  2. I have them in a .txt file so I can do whatever I want with them. Seems there are many companies that use the Global Cache devices for networking actions and the IR is one of them. It seems that most of the remotes I have like Sony, etc do not record but for a couple. But I have them all on a text file so I can import that file or copy some lines. I just don't know where ISY stores there IR codes. Maybe I need to convert the codes I have for it to work. There are over 150 of them soit will be good if I can get them to work, or at least some of them. Thanks
  3. Hi, Ok, so if the entire scene has just the 2 switches Kitchen Lights Scene Kitchen Light A switch (controller) Kitchen Light B switch (controller) does it require the same switches as responders also? Kitchen Lights Scene Kitchen Light A switch (controller) Kitchen Light B switch (controller) Kitchen Light A switch (responder) Kitchen Light B switch (responder) or does it require 2 seperate scenes, one with the controllers and the other with the responders? Thanks Also.... 1 - Where are the IR commands stored? 2 - Can I use the ones we have from Global Cache?
  4. Hi, I have a complex setup and working at it piece by piece. Had a question though...... In setting up switches, ((most of them are 3 ways)(2 switches)) so in that case do you recommend creating scenes for each light that has more than one switch running it so they are both controllers. Basically a scene like: Kitchen Lights Scene Kitchen Light A switch (controller) Kitchen Light B switch (controller) Is that the best way to do it? Thanks
  5. Hi, Sorry for the missed info in the dropdown. I didn't see the scenes below all the original listings. You can tell we have many switches.... Thanks
  6. Hi, Thanks for the help. That works - but there are 2 switches to the light so I was looking to see why a scene can't be accessed so it would turn the scene on or off since the scene has both switches as controllers making up that scene. Thanks for any insight....
  7. Hi, Seems to not be a straight forward as I would think. Simply wanted to use the sensor to turn the light off if no motion is sensed for 5 minutes. So if the light is "not off" (since it may be on at a percentage) and no motion is sensed for 5 minutes, turn the light off otherwise leave the light as is. So I guess it would need to check every minute or so and reset the timer ok for the 5 minute none movement. I don't want the motion sensor to turn anything "on", just off. Thanks
