peedeevee
  1. That did the trick. Thank you for your help. peedeevee
  2. I have a scene that I am trying to get working properly. It consists of controller - Keypadlinc 6 - button D responders - keypadlinc dimmer - load regular dimmer on/off module (non-dimmable lamp plugged into on/off module) The scene is set so that the keypadlinc dimmer is set for 32%, the regular dimmer for 50% and the on/off module to 0% - I want that light off in this scene. When I test it from ISY it works properly. The scene responders dim and the on/off turns off. But when I use it from the kepadlinc the on/off module turns on. I finally removed it from the scene because I could not figure it out. peedeevee
