bumana
Everything posted by bumana
  1. The problem is solved by using the control instead of status. Thank you!
  2. Hello, I am new to a ISY programming and I am trying to configure a dimmer switch and motion controller to control a laundry room light. I would like to turn on the light instantly as motion is sensed for which I needed to create a scene and add motion controller and dimmer switch into the scene. I wanted to control timeout by an ISY program so I have the flexibility in changing the timeout value through the program instead of changing the timeout value of the motion controller. Here is the motion controller configuration: Timeout (minutes): 0.5 LED Brightness: 100 Darkness Sensitivity: 128 Sensing mode: checked LED On: unchecked On command only: checked Night mode only: unchecked Scene Name: sLaundryMotion Laundry-Sensor = Controller LaundryLight = Responder Program Name: LaundryMotionTimer If Status 'Laundry-Sensor' is On Then Wait 45 seconds Set 'LaundryLight' Off Else - No Actions - (To add one, press 'Action') With this, as motion is detected for the first time, the light comes on and the light goes off after motion is not detected for 45 seconds. However, when the motion is detected again for the second time, the light comes on and stays on forever as I see that the program "LaundryMotionTimer" is not triggered. I also noticed that the status of the Laundry-Sensor remains "On" for indefinitely. Could you please help me to fix the issue? Thank you, Buddha
