kmanus
  1. kmanus replied to zachhll's topic in Amazon Echo
    I had the same problem, High and Low work when used in a phrase like "Turn On Living Room Fan High," but "medium" and "off" did not work through the Echo. To fix this, I used these phrases: -Turn On Living Room Fan High -Turn On Living Room Fan Half -Turn On Living Room Fan Low -Turn On Living Room Fan Stop The Echo still makes me repeat about 20% of the time, but the commands work. I'm thinking the Echo has "Off" and "Medium" as reserved words.
  2. OK, thanks, the way you worded it got me through it. I was assuming the "All Non-Toggle" button was just a way to switch the "Toggle On/Off" button for all buttons. Thanks Again!
  3. I think it's all set up correctly. The issue happens when I turn the toggle off, the fanlinc no longer responds to button presses. Pictures:
  4. Yes, there are 4 scenes for each fan (plus one scene for the fan light, so 5 total.) It's all working as it should until I turn the toggle off on the KeyPadLinc. When I turn off button toggle, the keys work as expected, but the FanLinc does nothing. With Toggle on, the buttons control the fan, but the button behavior is not what I want.
  5. I just installed my new ISY-994i, and have added all my Insteon devices (While removing all old links.) I Have 6 FanLincs controlled by 6 KeypadLincs. I've programmed each button to be either a controller or responder so that only one of the fan control buttons (Scene A,B,C,D) is lit at a time. It's all working, but I don't want the individual buttons to be toggles. When I press button D (Off), I want the fan to turn off. If I hit button A (High) I want it to either set the fan to high, or keep it as high if it is alrreay in that state. I've found the "Button toggle" menu under each button, but when I set the buttons to "Non-toggle," the buttons stop working completely (specifically, the buttons behave as intended, but the FanLinc does nothing.) What am I missing?
