dmatooch
Everything posted by dmatooch
  1. OK - I guess I thought this might be the answer but was hoping for a better solution . . . thanks. I'll post results after I replace the controller.
  2. Interesting result; After factory reset it looked like it was going to link - the progress bar started counting up. It got to about 5% and then failed with a different statement - now says, "Cannot determine Insteon Engine". I've been wondering if I will need to upgrade from my 99i to the 994i but still would think that if the motion sensor links, this one should also . . . ISY firmware: v.3.3.10 UI: v.4.5.1
  3. I've had an ISY 99i/IR PRO for a long time, and it's been reliable and easy to program - have about 20 devices connected. I just tried to add a 2845-222 hidden door sensor but have been unable to get the device to link. I have read through other posts for this device and understand the issues with linking a battery device - have tried several linking approaches. To narrow down the problem, I tried to link the sensor to an insteon hub - that worked fine. I have also previously linked a battery powered motion sensor to the ISY and that works fine. The ISY seems to start communicating with the door sensor (can determine the type of device when I have it auto discover) but still always comes back with "Cannot add insteon device" Below is what the even view log shows - any suggestions? Thu 08/11/2016 03:47:43 PM : [3B 25 3F ] Added to list of devices to link to ISY Thu 08/11/2016 03:47:43 PM : [iNST-TX-I1 ] 02 62 3B 25 3F 0F 0D 00 Thu 08/11/2016 03:47:43 PM : [iNST-ACK ] 02 62 3B.25.3F 0F 0D 00 06 (00) Thu 08/11/2016 03:47:43 PM : [iNST-SRX ] 02 50 3B.25.3F 30.6C.AF 2F 0D 02 (02) Thu 08/11/2016 03:47:43 PM : [std-Direct Ack] 3B.25.3F-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Thu 08/11/2016 03:47:43 PM : [iNST-TX-I1 ] 02 62 3B 25 3F 0F 10 00 Thu 08/11/2016 03:47:43 PM : [iNST-ACK ] 02 62 3B.25.3F 0F 10 00 06 ID-REQ (00) Thu 08/11/2016 03:47:43 PM : [iNST-SRX ] 02 50 3B.25.3F 30.6C.AF 2F 10 00 ID-REQ (00) Thu 08/11/2016 03:47:43 PM : [std-Direct Ack] 3B.25.3F-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Thu 08/11/2016 03:47:43 PM : [iNST-SRX ] 02 50 3B.25.3F 10.11.45 8F 02 11 (11) Thu 08/11/2016 03:47:43 PM : [std-Broadcast] 3B.25.3F-->10.11.45, Max Hops=3, Hops Left=3 Thu 08/11/2016 03:47:43 PM : [3B 25 3F 0 ] Calibrating engine version Thu 08/11/2016 03:47:43 PM : [iNST-TX-I2CS] 02 62 3B 25 3F 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 Thu 08/11/2016 03:47:43 PM : [iNST-ACK ] 02 62 3B.25.3F 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06 (00) Thu 08/11/2016 03:47:45 PM : [iNST-SRX ] 02 50 3B.25.3F 30.6C.AF 2F 2F 00 (00) Thu 08/11/2016 03:47:45 PM : [std-Direct Ack] 3B.25.3F-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Thu 08/11/2016 03:47:45 PM : [iNST-ERX ] 02 51 3B 25 3F 30 6C AF 15 2F 00 00 01 0F FF 01 E2 01 31 46 15 03 00 00 4F Thu 08/11/2016 03:47:45 PM : [Ext-Direct ] 3B.25.3F-->ISY/PLM Group=0, Max Hops=1, Hops Left=1 Thu 08/11/2016 03:47:45 PM : [3B 25 3F 0 ] Using Database Link Table offset 0x0FF8 (reported 0x0FF8) Thu 08/11/2016 03:47:45 PM : [3B 25 3F 0 ] Failed to add device Thu 08/11/2016 03:49:55 PM : [ Time] 15:49:57 59(0) Thu 08/11/2016 03:59:55 PM : [ Time] 15:59:57 59(0) Thu 08/11/2016 03:59:58 PM : [ Time] 16:00:00 59(0) Thu 08/11/2016 03:59:58 PM : [iNST-TX-I1 ] 02 62 38 7C E0 0F 46 00 Thu 08/11/2016 03:59:58 PM : [iNST-TX-I1 ] 02 62 38 7C E0 0F 46 01 Thu 08/11/2016 03:59:58 PM : [iNST-ACK ] 02 62 38.7C.E0 0F 46 00 06 IOOFF (00) Thu 08/11/2016 03:59:58 PM : [iNST-SRX ] 02 50 38.7C.E0 30.6C.AF 2B 46 00 IOOFF (00) Thu 08/11/2016 03:59:58 PM : [std-Direct Ack] 38.7C.E0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Thu 08/11/2016 03:59:58 PM : [iNST-ACK ] 02 62 38.7C.E0 0F 46 01 06 IOOFF (01) Thu 08/11/2016 03:59:59 PM : [iNST-SRX ] 02 50 38.7C.E0 30.6C.AF 2B 46 00 IOOFF (00) Thu 08/11/2016 03:59:59 PM : [std-Direct Ack] 38.7C.E0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Thu 08/11/2016 03:59:59 PM : [iNST-SRX ] 02 50 38.7C.E0 30.6C.AF 23 46 00 IOOFF (00) Thu 08/11/2016 03:59:59 PM : [std-Direct Ack] 38.7C.E0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Thu 08/11/2016 03:59:59 PM : [iNST-TX-I1 ] 02 62 38 7C E0 0F 46 02 Thu 08/11/2016 03:59:59 PM : [iNST-TX-I1 ] 02 62 38 7C E0 0F 46 03 Thu 08/11/2016 03:59:59 PM : [ 38 7C E0 1] ST 0 Thu 08/11/2016 03:59:59 PM : [iNST-ACK ] 02 62 38.7C.E0 0F 46 02 06 IOOFF (02) Thu 08/11/2016 04:00:00 PM : [iNST-SRX ] 02 50 38.7C.E0 30.6C.AF 2B 46 00 IOOFF (00) Thu 08/11/2016 04:00:00 PM : [std-Direct Ack] 38.7C.E0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Thu 08/11/2016 04:00:00 PM : [iNST-ACK ] 02 62 38.7C.E0 0F 46 03 06 IOOFF (03) Thu 08/11/2016 04:00:00 PM : [iNST-SRX ] 02 50 38.7C.E0 30.6C.AF 27 46 00 IOOFF (00) Thu 08/11/2016 04:00:00 PM : [std-Direct Ack] 38.7C.E0-->ISY/PLM Group=0, Max Hops=3, Hops Left=1 Thu 08/11/2016 04:00:00 PM : [iNST-SRX ] 02 50 38.7C.E0 30.6C.AF 23 46 00 IOOFF (00) Thu 08/11/2016 04:00:00 PM : [std-Direct Ack] 38.7C.E0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Thu 08/11/2016 04:09:59 PM : [ Time] 16:10:01 59(0) Thu 08/11/2016 04:19:58 PM : [ Time] 16:20:01 59(0)
