slpelts
  1. why do i get so many entries when I add a z wave device what do I do with them?
  2. slpelts replied to slpelts's topic in ISY994
    I have ISY 994
  3. slpelts posted a topic in ISY994
    I have a KPL and use button D to indicate if somebody is home or not. I turn button on when leaving I turn button on and off when arrive home. How can I from program turn that button on or off?
  4. thanks and sounds like good idea in general. However, in my case my different programs are already in different folders. for example, I have a folder for Winter, Summer, NightTime and such. but maybe given the suggestion I can change or rethink what I have done thanks again
  5. is there a way to stop all running program? There are situations when I would like to stop all programs that are currently running to kind of 'reset' things to start new program however, in thinking about this as I type, I couldn't stop the program that I use to stop all others. I can create a program that stops programs one by one and that might be only solution thanks
  6. slpelts replied to slpelts's topic in ISY994
    ok, Found the problem.. User error. this module was already set up... I wished it had given an error when I tried to add it vs. just closing the input screen. thanks for your help
  7. slpelts replied to slpelts's topic in ISY994
    Firm v.4.6.2 UI v4.6.2
  8. slpelts posted a topic in ISY994
    I am trying to add a 2457D2 as a new device. I cannot find that specific device in the drop down. Closest I can find is a 2457D2X and it will not link I try auto and it does not find it either. any suggestions? thanks
  9. slpelts replied to slpelts's topic in ISY994
    So I am guessing I should get one of these? Insteon 2992-222 Range Extender
  10. slpelts replied to slpelts's topic in ISY994
    But if it has been working up till now should that be an issue. All I did was move the PLM from one room to another. I realize that doing that can complicate things but I wouldn't think it would be a coupling issue????
  11. slpelts replied to slpelts's topic in ISY994
    I understand the different circuit. but the therm is now CLOSER to the PLM which really baffles me and is really line of sight. total distance maybe 8 feet. switches vary from a few years to new. I have replaced more of the KPL over time than anything because they go bad
  12. slpelts replied to slpelts's topic in ISY994
    hmmmm I am familiar with the two legs for the A/C. Just confused that it was working before w/o issue. Dual Band Devices... don't know that I have any. most everything is a wall switch no Range Extenders I can try to use extension cord to run PLM into a different wall socket but who knows where I will find that what is THE best solution? dual band device or range extenders
  13. slpelts posted a topic in ISY994
    I moved my 994i and PLM to new room in at home. now it can't communicate with some devices. one thing in specific the PLM is much closer to now but no go. Therm is 2441V Insteon Therm Adapter V.00 I so rarely have problems I have to always ask when something comes up. suggestions?
  14. I have been using it for about a year w/o any problems as a 6 button KPL. However, I am thinking if it is in 8 button mode maybe I will just get the new buttons and use a 8 button
  15. It has always been a 6 button KPL until a few days ago. I found User Guide but did not see anything about changing to 6 button mode from 8 button mode
