pankab
  1. Thank you Brian and Techman, it worked. For posterity, here is what I had to do: Remove the sensor from Eisy Relink it (manually, automatic discovery did not work) Right click and Write Changes to device Press the set button on the sensor so Eisy could see it Fortunately, my scenes still had the rediscovered sensors in them.
  2. Thank you Techman and Brian, after trying Insteon Motion I and IIs, I was able to make one work and not the other. I will try the rest of the ones to see if that one is broken. I will report back.
  3. Hi, After using the 994i for years with only minor problems, I got the IoX because I had to. Although I don't like that the Eisy is running warmer than the 994i, I hoped my system would be running smoother. But I am having problems with all Insteon motion sensors which the system no longer sees. I have tried- Restoring the IoX config from a working config after the migration about 100 times. - Restoring the PLM another 100 times. - I have Restored Device for the sensore another 100 times. - I bought a new PLM without success. I followed the proper instructions for Replacing the PLM. - I factory reset the new PLM without success. - Relinking the sensor but the system does not discover it What else should I try?
  4. Thank you for your responses. As some of you pointed out my issue with the Wait was that the If we being reevaluated which cause it to break. I moved the actions in a separate program with no if that was called by the original program and that fixed the issue. It is strange because it was working for me for about 2 years, but not sure why it decided to show up now. Thank you for your responses.
  5. Hello, I have been using this program to turn on the lights when a sensor senses motion. Then I have a few second delay and then i turn on a switch that has a siren plugged in to it. The last few days the wait time is screwing up the last action. The lights turn on fine, so the program kicks in, but then I don't see the switch that turns the siren to turn on. When I remove the Wait time from the program the siren starts fine after the lights turn on. What is up with the Wait time in the programs? What could be breaking the actions below it? Thanks, PK
