Randall Grogan
  1. I currently use MobiLinc as my portal back to the ISY994. I rarely use the MobiLinc applications for control of my system, but do periodically use the widgets on my iPhone/iPad to control scenes. Of late, I have started using Alexa to control lighting and fans. The vast majority of my hardware is Insteon, with some Philips Hue and z-wave devices (Schlauge). While I am very satisfied with MobiLinc and have not had reason to be concerned about my choice, I am curious what (if any) differences there are between the two services. Since they are mutually exclusive, I can't compare. Can anyone highlight what functionality might be available in one portal versus the other?
  2. Sure, I use the MobiLinc app on my smartphone to do that, which connects to the ISY through either the ISY or MobiLinc portal
  3. I am using the Mobilinc Portal with my ISY. I have two echo's and am using the Orchestrated MobiLinc application on my iPad. I have associated Alexa with my MobiLinc account when I enabled the "MobiLinc Smart Home" skill in Alexa. I have quite a number of scenes, devices and programs. However, the same subset of 43 are discovered each time. Only devices and programs are discovered (no scenes) and not all of the devices. I can not figure out why my other Devices and Scenes are not being discovered I have tried disabling the Skill in Alexa and reenabling/discovering, but the result is the same. What am I MISSING? Edit: I should note that I would be happy to ditch MobiLinc Connect, and go with the ISY Portal... my year is nearly up with MobiLinc. Feel free to convince me that this would be easier to troubleshoot.
